cossie pressurising
Old Jun 15, 2008 | 10:23 PM
jackos1's Avatar
jackos1
Default cossie pressurising
The story goes bought this off a mate who rebuild it with all the best parts motorsport developments then set her up running 32 psi and was very very fast shortly after headgasket went taking the alloy radiator with it this is were i bought it as my mate spent 10k on her then shit starts happening. i replaced headgasket with a 1.3mm triple layer one re torqued head and had to get the radiator re cored were she blew put all back together and she wont stop pressurising water in header tank. every time i give car some up the road and pull over water pissing out of header tank but if i drive off boost it seems ok it has been bled by all my local garages including ford. any ideas thanks
Old Jun 15, 2008 | 10:48 PM
mechanic28's Avatar
mechanic28
themoastat ok?rad fan switch?
Old Jun 16, 2008 | 04:25 PM
jackos1's Avatar
jackos1
ye they all brand new and been checked problem only occurs on boost
Old Jun 16, 2008 | 04:29 PM
rapidcossie's Avatar
rapidcossie
sounds like a head clamping problem or a cracked block.
cozmeister's Avatar
cozmeister
More boost Igor!
Sounds a bit like the turbo's pressurising the coolant system.....
Old Jun 16, 2008 | 04:33 PM
LHD220Turbo's Avatar
LHD220Turbo
seen this before where the block had a crack in it, not the most obvious but worth a check
Old Jun 16, 2008 | 04:34 PM
jacko's Avatar
jacko
both the above could be causes mate do a leak down check
Old Jun 16, 2008 | 05:09 PM
jackos1's Avatar
jackos1
thanks all for replies will get these all checked
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
