Ford V6 Distributor Help
Old Jun 12, 2008 | 07:04 PM
V6 Ste's Avatar
V6 Ste
Default Ford V6 Distributor Help
Hope someone can help i have just bought a land Rover with a Ford V6 in it.The problem is i am not sure what it's out of. Might be an old granada looking at it with a twin choke weber on it. I removed the distributor and marked the pos of the dizzy body to the block but did not mark the pos of the rotor arm. I have not got a strobe or timing light just basic tools so would be grateful for any advice how to solve this.
Oh and in idiot speak please just so i understand it ta.
Old Jun 13, 2008 | 05:44 AM
I'll dig out my V6 manual and post later today for you if no one has by then.
Old Jun 13, 2008 | 02:16 PM
V6 Ste's Avatar
V6 Ste
Cheers any help would be apreciated.bloke at work told me a way of doing it by setting it off timing marks on pulley but there dont seem to be any .Might be me being thick but the pulley is solid for about 2 thirds and then cut out for the other ????
Old Jun 13, 2008 | 03:19 PM
jon@work's Avatar
jon@work
dizzy at the front of the engine - essex
dizzy at the rear - cologne
Old Jun 13, 2008 | 05:39 PM
Can't find me book, may have thrown it!!
There WILL be some marks on the front pulley, get this in aligment with the metal pointer, which on a "KOLN", "cologne" engine(german) will be at about the 8 o'clock position, now line the SCRIBE mark on the dizzy body on the upper surface that the cap sits on so that the rotor arm points to this mark.
The timing can be set with a strobe once running to 9 degrees BTDC, with the vacuum disconnected, cylinder no1 is at the front left as you look at the engine facing the car.
Don't have details for the ESSEX engine I'm afraid so can't help.
Old Jun 13, 2008 | 07:32 PM
V6 Ste's Avatar
V6 Ste
Dizzy at the front so essex i presume any help muchly apreciated. Thanks for reply Tabetha.
Old Jun 13, 2008 | 10:38 PM
2wd turkey's Avatar
2wd turkey
u got the 3 litre then,from a capri or mk.1 granny.The cologne ,2.8 is the later granny and then xr4i.
Old Jun 14, 2008 | 06:01 AM
Essex could also be 2.5 litre, same thing will apply though to markings.
Old Jun 14, 2008 | 08:28 AM
V6 Ste's Avatar
V6 Ste
Thanks all, sure its a 2.5 but is there any way to check this off block number ??
borboyous
Aug 22, 2015 11:17 AM
Anutternutter
Aug 21, 2015 06:07 PM
Zoggon
Aug 10, 2015 10:39 AM
Sjieter
Aug 5, 2015 09:47 PM
