1.8 zvh conversion help!!!!!
Old Jun 11, 2008 | 05:04 PM
gavin1165's Avatar
gavin1165
Default 1.8 zvh conversion help!!!!!
has any 1 got a list of what needs doing to a 1.8 zetec bottom end to run in my fiesta rs turbo thanks
Old Jun 11, 2008 | 08:26 PM
borderfox's Avatar
borderfox
id like to know this meself.. i know there is a breather needs blocking up. oil returns taped and blocked. maybe one oil feed and a plate fo the water pump.
Old Jun 11, 2008 | 08:42 PM
Bomber's Avatar
Bomber
The original ZVH site: http://www.quantums.info/zvh.htm
Loads of info on there
Old Jun 12, 2008 | 09:47 PM
davidfox280585's Avatar
davidfox280585
blank 4 oil ways on the rear of the block off where the head mates. blank the front oil breather off tap a oil return in the front for the turbo and a breather in the rear buy a water pump adapter plate and usea 1.3 cvh cam belt tensioner either use a decomp plate or have the pistons skimmed to lower compression ratio and use a 1.6 zetec sump as it has exhaust cut out for exhaust to run through
Old Jun 14, 2008 | 09:34 PM
gavin1165's Avatar
gavin1165
ive forgot more than this kid nos haha
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
