Convert Escort from bolt to studs
Old Jun 8, 2008 | 09:13 AM
S2_RST_DK's Avatar
S2_RST_DK
Default Convert Escort from bolt to studs
I want to change the RS turbo from bolts to studs because the UltraLite A-Tec rims i bought almost a year ago come with the Ultralite titanium wheel nuts. So i looked at some UK webshops and they have some conversion kits, 4 bolts that fits into the hub... But is that all i need ? And what size or dimension do i need for a Ford fitment ??
Henrik
Old Jun 8, 2008 | 09:33 AM
bluescortcossie's Avatar
bluescortcossie
i would also like to know this
Old Jun 8, 2008 | 10:25 PM
AdamS2's Avatar
AdamS2
Used to be ford motorsport parts, wheel std kit part no. 9094499
doubt they`re are still available though or how much they would be if you could get a set.
Old Jun 8, 2008 | 10:37 PM
anodised's Avatar
anodised
i just went down fords and got some studs for a mk5 escort(cost about Ł12 for 16)
drill the hole on the rs hub to 13mm and press the stud in
Old Jun 8, 2008 | 11:20 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
As said, drill the holes out to 13mm and bang studs in, easy
Old Jun 8, 2008 | 11:30 PM
NEWTON's Avatar
NEWTON
i used mk2 escort stud,as said you need to drill
Old Jun 8, 2008 | 11:51 PM
becca s2rs's Avatar
becca s2rs
I fitted diamond cut rs7s to my s2 and wanted to use the ford alloy wheel nuts supplied with them, speedshack do conversion studs, you just screw them in i put a bit of thread lock on the stud and just turned them in, have been on the car for two years now with no probs. Much better than the stupid bolts, pain in the arse when removeing/refitting wheels.
Good luck
Old Jun 11, 2008 | 08:10 AM
S2_RST_DK's Avatar
S2_RST_DK
Thanks
Just ordered a set of studs from Speedshack...
Soon the Ultralite A-Tec will be fitted on the RST
Old Jun 13, 2008 | 07:04 PM
markie2's Avatar
markie2
ive got a set of studs for sale they just screw into bolt hole and you use your nuts
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
