cossi wont start
Old Jun 5, 2008 | 09:05 PM
bamcossi's Avatar
bamcossi
Default cossi wont start
ive got it turning over and it tries to fire but just wont grab hold and some times tries to fire on iduction stroke. ive checked the timing over and over and set it to the book please help.
Bam
Old Jun 5, 2008 | 11:08 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
was the car running and then this happend or have you done something and now it won't start?
to start you could check your crank pully has 4 teeth and make sure the sensor gap is between 0.6-1mm 0.8 is what I use.
HTH
Old Jun 5, 2008 | 11:10 PM
bamcossi's Avatar
bamcossi
ive never had the engine running bought it and was told it was running before it come out do u think the cams could be in wrong
Miller 3's Avatar
Miller 3
dizzy set up ok ?
Old Jun 5, 2008 | 11:13 PM
bamcossi's Avatar
bamcossi
when i set the engine to tdc the dizzy was set to fire at 3 so ive put that right wouldnt even attempt to fire before i did this.
Old Jun 5, 2008 | 11:15 PM
J1mbo's Avatar
J1mbo
B1mbo
all four injectors working? got spark on all 4 plugs ? could check just incase !??
Old Jun 5, 2008 | 11:17 PM
Dan@Rapid-Ford
Cams in wrong??? if you haven't fitted a timing belt then it 'could' be okay.
could be lots of other things, does the engine sound good? when you say set it up by the book what do you mean?
Check your crank sensor as I said above it might get you out of trouble.
Old Jun 5, 2008 | 11:18 PM
bamcossi's Avatar
bamcossi
had injectors out there all fireing not had no dealings with injectors they spat fuel out in no pattern at all is this correct and number 3 spark was a little week
Old Jun 5, 2008 | 11:23 PM
bamcossi's Avatar
bamcossi
is there any way of checking this without lending or buying an other one
what i mean is i set it to the book how it reads align all marks on pulleys and check for tdc in number 1 plug hole im a car painter not mechanic so i have to read and do what it says in the manual lol.
Old Jun 6, 2008 | 04:26 AM
stevecossy's Avatar
stevecossy
Hi When ya checked the timing was the lug on the bottom pulley lined up with the mark as thats tdc not the groove on pulley, also check rotor arm in dissy is exactly in middle of mark on dissy casing. Good luck.
Cheers steve.
Old Jun 6, 2008 | 07:03 AM
As said check the alignment with the camwheels pointers pointing towards each other and in line with the join between head and rocker cover, the crank pulley must be on the LUG nearest the "V" groove, NOT the groove itself(this is just for checking ignition timing, though not adjustable).
The phase sensor(dizzy) must be 100% in line of the centre of the rotor arm with the scribe mark on the dizzy body metal top where the cap goes down, about the 1 o'clock position.
If the phase was out it would still start no problem but would overfuel chronically, as it would go to batched firing as it does when cranking(I beleive).
As everyone seems to have missed it, check your PLUG GAPS, and set to 0.6mm, my own cossie would not even fire at the "correct" gap that ford specified on the sticker on the intercooler.
Old Jun 6, 2008 | 07:19 AM
bamcossi's Avatar
bamcossi
Cheers steve.
yer i noticed the groove and the mark so checked and set it with the mark its getting on my wick now taking longer to start the engine than it did to build the whole front end up lol thanx to all you lot on here ive a few things to check today cheers all Bam
Old Jun 6, 2008 | 08:14 AM
dojj's Avatar
dojj
Resident Wrestling Legend
are you replacing the engine in a cossie for a cossie or are you swapping an engine into anotehr car that's not originally a cossie?
and, if it's the first, did you get the engien from the same year cossie as yours as if the ecu's are different this may be your end reslut problem
Old Jun 6, 2008 | 11:24 AM
bamcossi's Avatar
bamcossi
yes my car is a gen rwd saf cossi the engine is a rwd out of nearly same age and is the ecu it very nearl fires then goes a little tight end tries to spin back a turn
Old Jun 6, 2008 | 11:45 AM
ShandzS1's Avatar
ShandzS1
Sounds like ign timing is way out....
Old Jun 6, 2008 | 11:48 AM
bamcossi's Avatar
bamcossi
thats what i keep thinking but ive checked loads of times and 2 of my mates have also checked its bang on even took cam cover off to make sure cams are in right
Old Jun 6, 2008 | 05:37 PM
Have a DOUBLE check on your firing order, and lead positions in the cap.
Old Jun 7, 2008 | 07:16 PM
Jamie@FastFord's Avatar
Jamie@FastFord
Jamie @ Fast Ford
I've had a very similar problem with mine before, which turned out to be a bad earth on the ignition amplifier. Might be worth checking.
Also, another common one is getting the plugs on the dizzy and crank sensor mixed up. They're both in the same place on the loom but one is grey and one is green, make sure the grey one goes to the dizzy and the green one goes to the plug on the end og the crank sensor.
Old Jun 8, 2008 | 01:38 PM
bamcossi's Avatar
bamcossi
has the alloy heat sink got be earthd had a look at my sensor wires ive the white going to white so presume thats correct thanks for tips now the bloody starter motors gave up so trying to get one of those at mo
Old Jun 8, 2008 | 02:02 PM
bamcossi's Avatar
bamcossi
just been made sure the amps earthed cant try it still no starter motor
should have kept my escos
Old Jun 8, 2008 | 02:28 PM
mechanic28's Avatar
mechanic28
sounds like you got your firing order wrong to me?
Old Jun 8, 2008 | 07:18 PM
bamcossi's Avatar
bamcossi
thats what i keep telling myself but checked it over and over im gona check again just to make sure STILL NOT GOT A BLOODY STARTERMOTER
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
Alun Gregory
Sep 6, 2015 09:40 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
