efi turbo problem
Old Jun 4, 2008 | 11:35 PM
iain_stewartrs's Avatar
iain_stewartrs
Wink efi turbo problem
i have a prblem here ive got a fiesta turbo with a stage 3 hybrid turbo on it and have blew 2 pistons at seperate times in the space of a month only boosting 10 psi obv cant cope with the boost any ideas on wat i shud do and wat pistons to use ?
Old Jun 4, 2008 | 11:55 PM
Stu @ M Developments's Avatar
PassionFords Creator
What did the pistons look like? have they cracked, or melted?
Old Jun 5, 2008 | 07:32 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I think once you get a new engine you should take it to someone to get properly mapped before you kill it again!
Old Jun 5, 2008 | 01:04 PM
iain_stewartrs
i have just took the head off there and the piston seems fine think it has to be a ring this time...... and for the other boy since the piston was done the last time it has been to AVA to be set up
Old Jun 5, 2008 | 07:48 PM
iain_stewartrs
im still getting a compression ratioe of ...90psi...140psi...120psi...140psi wat does any1 rcomend rings ? cheeRS
Old Jun 6, 2008 | 07:04 AM
Rings or valves.
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 17, 2015 12:21 PM
marky_g
Aug 15, 2015 10:43 AM
