zetec turbo manifold
can i use the 2.0 focus inlet manifold (the one with the end fed injectors)for a zetec turbo conversion if not were is the best place to get the two addapter plates needed to use the fiesta rs turbo inlet manifold which i think is the easyest option.
cheers all mike
cheers all mike
ferriday engineering will do you a plate about 90 quid i think but they are the dogs nuts.
rover inlet is a good choice too ferriday also do the plates for them as well.
Personally i think the rover inlet is a better choice that the fiesta and the mondeo one because the throttle body is at the side helping to keep the charge temp down it's not made from plastic like the mondeo one and flows better than the other two imho but depends on what sort of power your after.
couple of rover inlets on e bay at the mo.
