cossie oil?
Old May 29, 2008 | 12:39 PM
davcos's Avatar
davcos
Default cossie oil?
I have had to rebuild the bottom end of my 87 cossie , due to a big end letting go on me. The engine is running a stage 1 , about 280bhp . The oil that i have been using is the ford oil 0w40 fully synthetic , can anyone suggest any other oil or what i should be using .
Many thanks
Dave.
Old May 29, 2008 | 12:41 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
How long have you been running it on that for? If it's not long, then get some mineral oil in there for at least 500 miles..
Old May 29, 2008 | 01:51 PM
Don't tell us you have been using a synthetic oil in a new engine!!
Old May 29, 2008 | 03:03 PM
mechanic28's Avatar
mechanic28
0w-40 far to thin for cossie once u have run it in i woud go for either 15w-50 mobil 1 motorsport or 10-60 pro stuff
Old May 29, 2008 | 03:14 PM
davcos's Avatar
davcos
No im just getting ready to re fit the engine
Old May 29, 2008 | 03:16 PM
TurboShed's Avatar
TurboShed
Cossiemodo
You've been using 0w-40 on a Cossie, and you wonder why the big end let go??
Old May 31, 2008 | 03:02 PM
davcos's Avatar
davcos
The man that does the work on it has a grpN cossie rally car that is what he was putting in it its 5w 40 he was using , so any advice!
Old May 31, 2008 | 05:40 PM
LHD220Turbo's Avatar
LHD220Turbo
you need you use mineral oil if its new build; then after the engine has ran in you need to swap it for 10-50 silkolene pro s
dont use 0-40!!!!
Old Jun 1, 2008 | 05:37 PM
As said MINERAL for first 2000 miles, DON'T baby the engine either, you can after that use 10W40, BUT I wouldn't, as it gets too thin when hot, it will work ok just use a lot of oil in comparison to a heavier weight oil, will give a fraction more power(possibly), good for a group n, but not road car, use a 50 weight.
Old Jun 3, 2008 | 10:56 AM
davcos's Avatar
davcos
Thumbs up
Ok lads thanks for the advice
Old Jun 3, 2008 | 11:18 AM
Yura's Avatar
Yura
I use 5w-50 mobil 1. Is it good? Before I have use casrol 10w-60...
Old Jun 3, 2008 | 11:19 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Yeah it's fine.. just dont use 0w40.
Old Jun 3, 2008 | 11:42 AM
LHD220Turbo
silkolene pro S 10-50 is the best to use on a run in engine
Old Jun 3, 2008 | 05:13 PM
i use silkolene pro rs 10/50.
Old Jun 4, 2008 | 07:39 AM
Yura's Avatar
Yura
In Ukraine I cant find silkolene oils
Old Jun 4, 2008 | 11:02 AM
davcos's Avatar
davcos
Castrol uk are saying to use 10w 60 edge sport or alternative 10w 40 magnatec whats your opinion on that
dave.
Old Jun 4, 2008 | 11:12 AM
Yura's Avatar
Yura
dave.
as I know 10w 40 magnatec is semisintetic....
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
krypton
Sep 23, 2015 07:29 PM
Chopshop85
Sep 18, 2015 06:13 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
talon1
Sep 15, 2015 10:27 AM
