tial wastegate problem with avcr
Old May 26, 2008 | 09:52 AM
AzE_B's Avatar
AzE_B
Default tial wastegate problem with avcr
wonder if you lot can help i have the apexi avcr and a external 38mm tial wastegate on my motor, I have the top wastegate pipe going to the "com" and the side one going to the "nc" with a t-piece to the comp wheel,
the same as this pic here
http://www.toyotagtturbo.com/showthr...highlight=avcr
the problem i am gettin is it just keeps boosting up and up, and not what the avcr is telling it too
cheers az
Old May 26, 2008 | 10:17 AM
Bomber's Avatar
Bomber
What pressure spring do you have in your Tial?
Old May 26, 2008 | 10:21 AM
gaz_turbo1's Avatar
gaz_turbo1
don't no what spring he has in it but it's will keep boosting above 2 bar tho
Old May 26, 2008 | 10:32 AM
Bomber's Avatar
Bomber
NO is vented to atmosphere - move the nipple from NO to NC.
Run a line from your boost reference at the compressor outlet (or boost pipe that goes to the throttle body) to the bottom nipple of the external wastegate. Put a "T" in this line, and run the hose from the T to the NC nipple on the AVC-R solenoid.
Run a line from the top nipple of the wastegate to the COM nipple on the AVC-R solenoid.
Is it plumbed in like the above?
Old May 26, 2008 | 10:37 AM
gaz_turbo1's Avatar
gaz_turbo1
yeah it set up the exact same as what u just said and the pic above, just that we have blocked the "no" end
Old May 26, 2008 | 10:38 AM
Bomber's Avatar
Bomber
Here is the manual:http://www.apexi-usa.com/pdfInstallation/45.pdf
Look at setting the Apexi - Page 18. If he still has troubles set the unit to monitor mode (so the boost is set by the External Wastegate) and get it along to somebody who can set these up.
Old May 26, 2008 | 10:40 AM
Bomber's Avatar
Bomber
DO NOT BLOCK THE NO PORT. Leave it open to atmosphere.
Old May 26, 2008 | 10:48 AM
gaz_turbo1's Avatar
gaz_turbo1
yeah been through tht manual and other one's like 20 times everything is there just keeps boosting, just thinking if some one else has had this problem before
Old May 26, 2008 | 10:51 AM
Bomber's Avatar
Bomber
Have you tried the above?
Old May 26, 2008 | 11:00 AM
gaz_turbo1's Avatar
gaz_turbo1
yeah mate have, will go out and have a play around and see what happens, cheers mate
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
pabloXR
Sep 21, 2015 12:42 PM
