A few questions:)
Old May 25, 2008 | 07:33 AM
spmotorsport's Avatar
spmotorsport
Default A few questions:)
I own a 1990 ford sapphire cossie 4x4 and was planning on doing a full oil service on me car, what I mean by full oil service is engine oil, front/rear diff oils, transmisson oil
but being this is the first cossie I have owned am kinda stump as the front and rear diff don't have any drain bungs that I can see, had a read of workshop manual and found for the front diff you take the bottom plate off but couldn't see how to do the read diff, possibly missing a page or 2, any help on this would be great, also am thinking about taking the engine out for a cleanup + freshenup but have never ever taken an egine out of one these.
I was thinking about undoing all the sump bolts, undo the gearbox and lifting it straight off the sump/front diff, does this sound like a good idea?
again any help would be appreciated
cheers
hadyn bruce
new zealand
Old May 25, 2008 | 08:41 AM
The REAR diff just has a filler/level plug, make sure to use LSD oil in it.
Unless you know that it has been done change the FUEL FILTER, and then every two years.
Also do a fuel pump rewire followed by a fan rewire if you want it to last.
Old May 25, 2008 | 01:00 PM
mechanic28's Avatar
mechanic28
you have to remove the rear plate on the diff to drain the oil!if there is nothing wrong with your engine would leave well alone!!!!
just watching you lot giving us a total beating at cricket
Old May 25, 2008 | 04:46 PM
Bugger did not notice us getting thrashed at cricket(again!!) would not have answered if I did!!
Old May 25, 2008 | 08:20 PM
mechanic28's Avatar
mechanic28
its ok now!we on top at the mo
Old May 26, 2008 | 06:45 AM
Phew that was close then, not like everyone beats us all the time!!
Old May 26, 2008 | 08:43 AM
spmotorsport
that's the new zealand cricket team for ya, when you think they might be going all right there brains start thinking and it's a downward spiral from there
Old May 26, 2008 | 09:52 PM
mechanic28's Avatar
mechanic28
and we won :cont ent:
you drained your oil yet
Old May 27, 2008 | 06:35 AM
Aaroncast's Avatar
Aaroncast
--------no Pages Are Missing!!!!!!!!!!!!!!!!!!!!
jdance
Ford Focus ST
Aug 23, 2013 09:14 AM
szaboakos
Apr 16, 2013 01:41 AM
haz87
Dec 20, 2012 07:53 PM
redzuki1
Jun 7, 2009 03:20 PM
