pykey gti reving problem still!!!!!!!!!
Old May 18, 2008 | 09:26 AM
JohnnyP's Avatar
JohnnyP
Default pykey gti reving problem still!!!!!!!!!
hello all! hit a pidgeon yesterday! mullard the front bumper! lol! not havin much luck this wk,me gti still wont rev threw the gears still, ive changed the fuel filter, air filters, maf,throttle switch,flywheel sensor,thermostat coolant sensor,the sensor in the air intake pipe and still no luck, would the crank sensor cause this problem? is it diagnostic machine time!! cheers pykey!
Old May 18, 2008 | 12:56 PM
3i_gaz's Avatar
3i_gaz
coil pack? plugs? leads?
Old May 19, 2008 | 08:49 AM
Fiesta SuperSport's Avatar
Fiesta SuperSport
Coilpack, leads have been changed, I don't know about the plugs!
Its got me stumped!
Old May 25, 2008 | 03:36 PM
JohnnyP's Avatar
JohnnyP
HELLO MATE, THIS CAR IS WORKIN ON MY TITS NOW... IT WONT REV WHEN YOU PUT YOUR FOOT DOWN,GETS WORSE WHEN IT GETS HOT, IS IT TERMINAL????? THE PLUGS AND LEADS WERE CHANGED ABOUT 6 MONTHS AGO, THE CRANK SENSOR HAS BIN CHANGED, ALL THE AIRFLOW SENSORS,COULD IT BE THE FUEL PUMP? THE REGULATOR ON THE INJECTION SIDE? ANY IDEAS ANYONE? PLEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEASE HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 25, 2008 | 04:12 PM
S2Steve's Avatar
S2Steve
Injectors?
Old May 25, 2008 | 06:45 PM
JohnnyP's Avatar
JohnnyP
ive done about roughly 6 to 7000 miles on the leads and plugs,ive got a spair second hand set of injectors that my mate got me so i mite just swop them over, ive just checked the vacuum pump pipes and there r no leaks,thers a black box behind the o/s headlight with a lead goin to it,does anyone no wot it does?????????
Old May 25, 2008 | 06:48 PM
S2Steve's Avatar
S2Steve
Might just be a supressor of some sorts. I'd swap the injectors mate, if they're clogged on damaged then it will cause you all sorts of driveability problems as will poor spray patterns.
Old May 25, 2008 | 06:55 PM
JohnnyP's Avatar
JohnnyP
the exhaust had to be changed for the mot as the baffles had blocked the exhaust nearly completly up,its just passed its mot with the exhaust and a spring had snapped,would that cause any damage to the engine????
Old May 25, 2008 | 07:36 PM
JohnnyP's Avatar
JohnnyP
cheers mate, my names jonny by the way! ile do it ta morraile let ya no how i get on
Old May 25, 2008 | 07:53 PM
S2Steve's Avatar
S2Steve
No problems mate, its worth a try swapping them, sounds like you've checked just about everything else! My names steve if you hadn't guessed
Old May 25, 2008 | 08:07 PM
rapidcossie's Avatar
rapidcossie
the bird you hit swapped the leads round?
Old May 25, 2008 | 08:11 PM
JohnnyP's Avatar
JohnnyP
ha ha!!!!! i hit it at 90 so there were wasnt alot left of the birdie!!!
Old May 26, 2008 | 09:22 PM
JohnnyP's Avatar
JohnnyP
tryed the injectors and it aint cured the problem. cannot figure it out for the life of me!!!must be the wiring some where?????????????????????
Old May 28, 2008 | 03:48 PM
JohnnyP's Avatar
JohnnyP
Default pykey! gti has bit the dust!
its blown up! r.i.p
Old May 28, 2008 | 03:59 PM
JamesH's Avatar
JamesH
Lol, I was going to suggest, did you replace both coolant temp sensors?
Theres the one comes straight out the top of the thermostat housing, and the one that comes out the bottom at a 45° angle...
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
cossirob
Sep 16, 2015 07:39 PM
