Missfire on boost
Old May 14, 2008 | 06:53 PM
se mk3 cabbie's Avatar
se mk3 cabbie
Default Missfire on boost
What normally causes this? i have had the timing checked, new dizzy, plugs,leads, rotor arm, had the fueling set but still bad, drives fine if driven off boost but when it kicks in it really holds back and misses, have been told maybe the cam is worn, sound right? any ideas please on what to try next, thanks
Old May 15, 2008 | 11:30 AM
mikedaf2's Avatar
mikedaf2
its normally the plug gaps to large if you are running standard ignition system
Old May 17, 2008 | 08:13 AM
se mk3 cabbie
plug gaps are all fine
Old May 17, 2008 | 02:29 PM
antony215's Avatar
antony215
Escort Rs Turbo
What did you set them to?? and have you tryed another coil??
Old May 17, 2008 | 02:40 PM
TinTin Escy's Avatar
TinTin Escy
Sticky wastegate actuator!!! Check if you can pull it open quite easily with some grips, or try doing it by hand but MAKE SURE ITS COLD!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
