pykey esc.gti
Old May 12, 2008 | 09:09 PM
JohnnyP's Avatar
JohnnyP
Default pykey esc.gti
hi there, um new to this website so bare with me! i have a problem with my mk6 escort gti, when u start it up from cold it runs perfectly, but when it starts to get hot it starts to try and stall and wont rev or accelerate and cuts out!.when u leave it to cool down it runs perfect again, ive changed the airflow meter, the throttle position switch, the coil pack for the leads, i havn't tryed the cam sensors yet,can anybody help me out!?!?cheers pykey!
Old May 13, 2008 | 05:41 AM
I would look at a new coolant temp sensor.
Old May 13, 2008 | 07:53 AM
Fiesta SuperSport's Avatar
Fiesta SuperSport
Agree completely with Tabetha on this,
Mind you I did tell you this over the weekend you pykey cunt!!!
Cheers Stevie
Old May 13, 2008 | 08:10 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Could also be the Lambda sensor, it only kicks in when warm.
Old May 13, 2008 | 08:13 PM
LHD220Turbo's Avatar
LHD220Turbo
on a different car i had same sort of issue, changed all type of sensors and meters etc....it turned out to be a blocked fuel filter that was somehow getting pressure when hot....exactly the same symptons as you've described
Old May 13, 2008 | 08:39 PM
JohnnyP's Avatar
JohnnyP
Default pykey gti
changed the thermostat sensor with the aid of my mate stevie! and it ran alright for a while then it wouldnt rev under load over 4500 rpm, didnt try cutting out but i didnt drive it that far but we did run it up till it was hot and the fan kicked in a couple of times.Thanks a lot for the feed back that ive had off all of u, its much appreciated! ile try the filter next as it hasnt bin changed for a while...... cheers again pykey!
Old May 13, 2008 | 09:33 PM
Fiesta SuperSport
Right will try Lambda sensor tomorrow, what time do you finish work tomorrow Pykey? Do you wanna meet me at whip street chantry branch??? Im sure I have got one there you can try! I can be there for about 5.30???
Old May 14, 2008 | 05:10 AM
FRom waht you describe, it won't be the lambda.
Lambda's, DON'T "only kick in when warm"!!
Old May 14, 2008 | 10:15 PM
Wardy257's Avatar
Wardy257
Unplug the MAF and see if she is better.
Old May 15, 2008 | 09:01 PM
JohnnyP's Avatar
JohnnyP
wots a maf?
Old May 15, 2008 | 09:02 PM
BigErn's Avatar
BigErn
could be a crank sensor problem, seen it happen this way on a few vauxhalls.
Old May 15, 2008 | 09:24 PM
JohnnyP's Avatar
JohnnyP
maf,mass airflow sensor? crank sensor is behind the bottom fly wheel isnt it?????????
Alabama Hot Pocket
17
Aug 24, 2008 11:30 AM
JohnnyP
May 28, 2008 03:59 PM
DaveEscos
25
Mar 23, 2006 07:30 PM
DaveEscos
20
Oct 22, 2005 10:29 AM
