Best cams for stage 3 spec
Old May 12, 2008 | 09:16 AM
lamb chops's Avatar
lamb chops
Default Best cams for stage 3 spec
My cars not been making the power it should since i redone the timing and fitted verniers, ive set the cam timing to stardard but its only making 270 BHP and with a flatter than flat power curve.. I dont know the spec of the cams just presumed they were standard but now im not sure..
Ive checked them and they appear standard with no markings stamped on but thats not to say they have not been reground at some point i guess.. My head has seen some porting so cams wouldnt be out of the question but have no recepts for the build work so not sure
If i were just to buy some new cams what would be best for a stage 3 motor with .48 T34 and some light head work? Oh and greens.
Old May 12, 2008 | 09:39 AM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
depends on pistons m8
Std pistons i would go bd-12 inlet bd-10 exh to get some more top end or std exhaust to get a really torque engine
Old May 12, 2008 | 09:46 AM
Dan's Avatar
Dan
Standard Cams are absolutely fine John at that spec
I'd be wanting to find out why the fook the poor old girls only Stage 1 power with a T34 though mate!?
Old May 12, 2008 | 09:54 AM
lamb chops's Avatar
lamb chops
Yeah i know Dan.. I think ive decided to send to car to ahmed for a complete setup. leave it with him for a couple of weeks so he can go through it all. Wont be cheap but at least should come back sorted..
The centrelocks are also going to be for sale!!
Old May 12, 2008 | 12:21 PM
Have you measured the lift/duration of the cams, as if they have more lift the pistons SHOULD have been pocketed with valve cut outs.
You need to ask what power you want and go from there, but as said std cams are a safe choice and will get you 350 on greens.
Old May 12, 2008 | 02:03 PM
lamb chops's Avatar
lamb chops
Thanks for the reply folks, ive been offered a set of BD10's for good money would these "work" with my engine spec? Do the 10's give more top end power or better torque?
Old May 12, 2008 | 02:24 PM
The std cams are BD8, so these BD10 are the next step up, impossible to say WITHOUT knowing if you have valve cut outs or not, if you don't they will almost defintitely hit the pistons.
The exhaust ones does not really need touching when on greeens, indeed a BD14 INLET ONLY would be my first choice with a step up in injectors, with STD exhaust cam.
Old May 12, 2008 | 02:38 PM
silky16v's Avatar
silky16v
Get on That!
keep with the OEM cams, perfect for stage3+ sounds like you need you verniers needs timmed up
Old May 12, 2008 | 05:47 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
yep, std cams are good for much more power then you will ever see from your baby turbo, and give you massive torque, which makes a real nice road car.
as a general rule for cams, the wilder you go, you gain top end bhp, but loose torque on the way....add this to the fact your turbo makes its power low down on a .48, it wouldnt make much gain imo
as for piston /valve pockets, it depends how much has been skimmed off head/block, what head gasket thickness, and how they are dialled in.....when i spoke to stu about this, he said he has seen std pistons clear a bd14.....iirc
Old May 13, 2008 | 02:57 PM
Dan's Avatar
Dan
Why the fook are they going to be for sale John!!
Good call going to Grove mate, you know it'll come back ok, like mine with MSD
Old May 13, 2008 | 03:08 PM
Luca's Avatar
Luca
Lukesville
Going to be Dan they are For Sale
Old May 13, 2008 | 03:59 PM
And I've seen UNSKIMMED heads with valve marks on the(std) pistons.
Old May 13, 2008 | 04:36 PM
lamb chops's Avatar
lamb chops
Cheers Dan,
The wheels were only really a short term extravagance and when the cars not running right and needs more money spending they are going to have to go.
Thanks for the advise on the cams guys going to have to check the lift etc of mine and work out if they are standard and go from there.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
