map sensor help
Old Apr 27, 2008 | 07:37 PM
mk6 turbo's Avatar
mk6 turbo
Unhappy map sensor help
As i cant find the wiring diagram to connect my frst loom too my escort,is it possible to wire a map sensor connection onto a standard escort wire loom so that i wont have to change the engine bay loom,and if so,can anyone tell me what wires go where..Thanks.
Old Apr 27, 2008 | 08:25 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
youl have to be more specific mate whats the escort youve got? apart from mk6 and i presume you mean its on an air flow meter at the mo? if so it would be much easier to fit the other loom!
Old Apr 27, 2008 | 08:45 PM
mk6 turbo's Avatar
mk6 turbo
Yes,it has the air flow meter and I would fit the ofac frst loom but i have no idea as to the wiring of the block connector that connects the rest of the loom to the engine bay loom,what i mean is,i know what each wire on the ofac engine bay loom is for but as the escort wiring is different and the wire colours are different on the block connector,i dont know what wires i need too join the frst loom too.Maybe you know or could tell me where i could find out...By the way,its a 1998 escort caborlet...1.4ltr efi....Is that info of any use to ya...Thanks.
Old Apr 27, 2008 | 08:56 PM
NEEDFORSPEED
what are the colours on the car side of the loom? the looms are a doddle to wire up but a little harder to explain!
Old Apr 27, 2008 | 10:37 PM
mk6 turbo's Avatar
mk6 turbo
Hi mate..this is how the wires are numbered on the block connector from the the car side of the loom...
pin 1 : purple/blue stripe
pin 2 : black/blue stripe
pin 3 : white/black stripe
pin 4 : black/red stripe
pin 5 : purple/blue stripe
pin 6 : black/green stripe
pin 7 : orange/blue stripe
pin 8 : purple/yellow stripe
pin 9 : blank
pin10: purple/black stripe
pin11: black/blue stripe
pin12: blank
This is the info i got on my ofac loom.
Pin 1: Ignition Live
Pin 2: Pin 22 (ECU) to the Fuel Pump Relay
Pin 3: Fed From DIS coil pack to the Rev counter
Pin 4: Pin 20 (ECU) Current return
Pin 5: Pins 57 & 37 (ECU) to the Fuel injection Relay
Pin 6: Oil Pressure
Pin 7: B+ (Constant Live)
Thanks.
Old Apr 28, 2008 | 06:48 PM
mk6 turbo's Avatar
mk6 turbo
Just to let ye know that i sorted out the wiring so now i have my escort running 100% on ofac,im going to try it on ofab during the week
Old Apr 28, 2008 | 08:11 PM
NEEDFORSPEED
sorry i was late repling lol at least its sorted
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
