cossy head gasket
Old Mar 6, 2008 | 09:36 PM
cos400's Avatar
cos400
Angry cossy head gasket
Best way to tell if head gasket has gone as loseing water. i have looked under the engine turbo side and there is a white staine in the middle of the block but it look's like it comes from higher up.there is no mayonaise like in cam cover or the header tank?
Old Mar 6, 2008 | 09:40 PM
Saaamon's Avatar
Saaamon
Look at the oil filler cap to see if theres white mayo looking sludge, check the header tank for oily water and if your still unsure you can get a head gasket testing kit.
Old Mar 6, 2008 | 09:52 PM
cos400's Avatar
cos400
Default head gasket
where do i get a head gasket testing kit from?
Old Mar 6, 2008 | 09:54 PM
cos400's Avatar
cos400
where do i get a head gasket testing kit from please mate?
Old Mar 7, 2008 | 09:37 AM
coswurv's Avatar
coswurv
any motor factors will sell one or take it to your local garage and the will test it for you mate.
Old Mar 7, 2008 | 10:00 AM
grcossie's Avatar
grcossie
Set cooling system under pressure, whit a pump, and locate the leaking. What side of block do you see white staine ?
Old Mar 7, 2008 | 10:34 AM
Dave Henshall's Avatar
Dave Henshall
the other easy test is just to ask a garage to put the exhuast testing probe in the top of the header tank -(not under the water though) this will show up any combustion by products being passed into the cooling system - a sire sign the HG is leaking.
Old Mar 7, 2008 | 05:40 PM
The normal place for a gasket to go is above the rearmost core plug on the exhaust side, especially on 2wd(heads) as water ways different shape, and gasket not supported as well as a 4wd one.
If losing ONLY water, not performance, and no water in oil then it has obviously gone outwards so sniffer test will not show anything, where abouts Norfolk are you, as some other people could have a look/help see ?
tabetha(norfolk)
Old Mar 7, 2008 | 06:47 PM
silky16v's Avatar
silky16v
Get on That!
worth every penny
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=150213575330
Old Mar 8, 2008 | 07:34 AM
It may be worth every penny, but is a bit pointelss if it has not bust through the sealing ring, or into a oil way as will be a waste of money.
As a stain can be seen, might as well do the free stuff first.
Some would pay for it some not, but some pay thier bills and some don't!!
Old Mar 8, 2008 | 08:17 AM
BIL N KEL's Avatar
BIL N KEL
not good mine had this and the head was corroded badly near the water ways letting the water piss out the side of the head
Old Mar 8, 2008 | 11:32 AM
If it is corroded it can easily be welded and skimmed, so all is not lost, they generally corode due to lack of anti freeze.
Old Mar 11, 2008 | 12:01 AM
NEILNATO's Avatar
NEILNATO
SCOOBY DOOBY DON'T!!!
Check if the rad hoses are getting hard after a run, if so the gasket has failed on the water jacket
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
pie-face
Sep 15, 2015 10:43 AM
Chopshop85
Sep 12, 2015 06:42 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
