Mondeo Mk1 Changing speakers help...
Old Feb 22, 2008 | 07:21 PM
MondeoMike's Avatar
MondeoMike
Question Mondeo Mk1 Changing speakers help...
Hi all, 1st post and that...
I want to change my front speakers of my 1996 Mk1 Mondeo but cant seem to seperate my door panels off the chasis.
I have done the 5 outer screws and the covered one at the bottom right and where the inside door handle is, am I missing anything else? it seems to be fixed down at the top but it wont budge and for obvious reasons I don't want to force it!
Also, what is the correct size speaker I should be looking for? (I was going to find out when looking at my old ones, but as im on the ford forum I'd though I would ask anyway).
Mike.
Old Feb 22, 2008 | 07:33 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
inside the bit you rest your arm on/hold screws
Old Feb 22, 2008 | 07:39 PM
MondeoMike's Avatar
MondeoMike
ah sweet, just had a look and noticed the hole, will get onto it in the morning.
Cheers!!
Old Feb 23, 2008 | 07:43 AM
The speaker are an odd FORD size, you can just buy or make templates to use round speakers, 6" if I remember right.
My dad has just done the rears on his mk1, used some FLI speakers, sounds really good to be honest, had pioneers in it when we got it, but they were not up to much, and the numpty had had put the three ways in the rear and the two ways in the front, so soon swapped around.
Old Feb 23, 2008 | 08:02 AM
Matt Baxter's Avatar
Matt Baxter
Back in black!
as for speaker size its 6x8 but with a little bit of trimming you could fit 6x9 if you wanted
Old Feb 23, 2008 | 08:46 AM
Fiddy's Avatar
Fiddy
6x9's will fit, just re drill the holes, i did it in both my old mk1's. use jbl 6x9's, they do fit, some other makes have bigger magnets and wont fit.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
rex647
Mar 6, 2022 06:20 AM
Chopshop85
Sep 12, 2015 06:42 PM
yorkie92
Sep 6, 2015 05:34 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
