Idle adjustment on a series 2 RST
28-01-2008, 09:45 AM
I want to adjust my idle speed when ticking over on my S2, Is it in easy job. When warm it seems to be ticking over at 1400 rpm, I want to take it down to about 1000 if poss.
Many thanks
Nick
28-01-2008, 10:18 AM
Skint Passionford User
There's a small screw under the metering unit iirc
28-01-2008, 12:03 PM
if it's mfi like mine it's by the throttle position sensor a brass screw with a spring on it. im not sure on the efi
28-01-2008, 12:08 PM
Quote:
Dead right, i was thinking of the mixture screw
28-01-2008, 12:52 PM
28-01-2008, 04:12 PM
the screw at the bottom of the throttle body screws inwards to reduce the revs!
28-01-2008, 04:14 PM
28-01-2008, 09:10 PM
The efi idle screw is in front of the iscv on throttle body,screw in for lowering,out for raising idle speed
A.t.p
23-10-2015 07:54 PM
AJC
08-10-2015 11:09 AM
07-10-2015 12:56 PM
Fezman1
02-10-2015 01:22 PM
Kiran1600E
11
02-10-2015 11:35 AM
