mk6 escort keys and locks
Old Jan 26, 2008 | 06:33 PM
nrg19uk's Avatar
nrg19uk
Default mk6 escort keys and locks
hi folks
i was thinking about replacing the locks on my escort, is it just a case of changing the transponder or do i have to change the ecu?
thanks
neil
Old Jan 28, 2008 | 09:21 PM
MADFORDIT's Avatar
MADFORDIT
Why do you want to swop your locks? which locks have had it?
Old Jan 28, 2008 | 09:46 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
if its on an escort just change your locks, maybe you can get the chip from your key into the new keys?
but the locks have nothing to do with the coding, nor does the ignition. Only reason the ignition key needs to be coded is cause it goes to the "blackbox"
you can get around this by taping one of your coded keys to the black box under the cowelling, then just changing your locks to any set, and your new keys wont even need to be coded.
Old Jan 28, 2008 | 09:54 PM
nrg19uk's Avatar
nrg19uk
Default hi
hi there thanks for your reply
when i brought my car it had a red key with it but when i got it home i then realised it only opened the boot, the other keys all open the doors and start the car apart from the boot.
Old Jan 28, 2008 | 09:55 PM
nrg19uk's Avatar
nrg19uk
hi there thanks for the reply
does this mean i would have to changed the ignition barrel?
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
tankybaby66
Aug 9, 2015 07:13 AM
