will start , wont start
Old Dec 31, 2007 | 01:23 PM
davcos's Avatar
davcos
Default will start , wont start
Ive just re done the head on my 87 cossie had a small problem with knocking in the head but it has calmed down , Thanks for all your replies . Now its having problems starting , turn on ignition and the engine management light does not go out , its not getting either fuel or spark then its might start a few hours later . Is it the ignition module, map sencor or the ECU. Any advice on this ,
Regards
Dave.
Old Dec 31, 2007 | 03:00 PM
col cos1's Avatar
col cos1
you looked at phase sensor in dizzy?
Old Dec 31, 2007 | 03:08 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
Old Dec 31, 2007 | 03:46 PM
Phase sensor will not stop spark but CRANK POSITION SENSOR will.
Do the wiggles test on the connection/loom.
Old Dec 31, 2007 | 04:25 PM
Lloyd's Avatar
Lloyd
Both the signal from the distributor and the RPM / TDC-sensor enable the module to identify the phase of each cylinder. This information forms the basis on which the ECU module decides on spark timing and fuel injection
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
