Zetec Turbo conversion and turbo selection?
Old Dec 26, 2007 | 11:14 PM
xrt-mart's Avatar
xrt-mart
Default Zetec Turbo conversion and turbo selection?
I am in the middle of doing a zetec turbo conversion on my XR2 and at the moment and the spec has got a little higher than originally intended. However I am still on original rods with arias pistons so BHP is limited to 260-280 BHP from what I can see.
The problem is that at the moment I have a standard ERST turbo which will need upgrading.
I will be soon taking the engine to Ian Howell for him to do the machining work to the engine/head. I was wondering if I could use something off the 200sx, pulsar or similar for my turbo with a FRS manifold? I can get the but don't have a turbo to play with to test if it would work. I would ideally just get a GT28rs but don't really have the cash.
Hope this all makes sense
What would you lot do if you were me?
Mart
Old Dec 27, 2007 | 04:21 AM
The GT range are good, but headwork will cut down lag ENORMOUSLY, so may not be needed, so might as well save your money and use elsewhere.
I would just use a modded T3, maybe even cutback for more low down/earlier boost, if limited to 260/280, that would be a cheap option, or T25.
Old Dec 27, 2007 | 09:18 PM
xrt-mart's Avatar
xrt-mart
Im not that bothered about using a GT series to be honest and the head will be staying the same due to funds.
I really need a turbo better suited to the 2.1 so would I be better just swapping to a cossie turbo for example?
Cheers for the advise.
Mart
Old Dec 27, 2007 | 09:20 PM
xrt-mart's Avatar
xrt-mart
Although with a cossie T3 I will still need the head drilling so it seams a double spend when the money could be used for a 2.0ltr sized turbo on the frs manifold
Old Dec 28, 2007 | 07:50 AM
I have never done one of these, but a friend has done loads of cvh/zetec things so will ask for you.
Old Dec 28, 2007 | 11:27 AM
woolford's Avatar
woolford
ill be starting mine soon.. started getting parts last year.. Zetec blacktop standard rods wont support 260+ not sure about silver top but wouldnt think much different... and a gt25 will be good for about 300 310 maybe dependant on parts and spec...
Old Dec 28, 2007 | 07:11 PM
xrt-mart's Avatar
xrt-mart
Yeah I was thinking of something like off a S14a for example on the FRS manifold.
I could probably sell my turbo for 150ish and also save the 75 for the head drilling so that would leave at least 225 for a turbo.
Old Dec 28, 2007 | 07:58 PM
xrt-mart's Avatar
xrt-mart
Also how about a cossie T3. How much BHP will they take upto on a 2.1?
Old Dec 28, 2007 | 08:28 PM
woolford's Avatar
woolford
phone scc and see if they have any second hand turbos for sale if you buy off ebay or some1 you don't know what your getting... a gt25 i think is about 300 but def no more than 350 and you know it will work...or risk getting a t3 and getting it to fit on the focus manifold...
Old Dec 28, 2007 | 09:23 PM
xrt-mart's Avatar
xrt-mart
280 BHP is my maximum so a gt28 should be up to the job.
I would also presume the cossie type T3 with a .48 housing should see me up to this area ?
Old Dec 31, 2007 | 02:16 PM
gtit's Avatar
gtit
is it a focus rs manifold lyk mine? u need a t25, seen in fast ford on their zetec turbo build they got a focus rs turbo for 150 i think second hand from sumplace lyk puma speed, tht way you can use the focus down pipe with a slight bit of bendn,
Old Dec 31, 2007 | 07:05 PM
xrt-mart's Avatar
xrt-mart
If I could get a focus turbo for 150 I would be 100% laughin
Old Jan 1, 2008 | 11:26 AM
woolford's Avatar
woolford
its a full guide in performance ford not fastford and i got my turbo were they got theres but you wont get one from SCC for the same price.... 300 or 350 you will get one second hand off
Old Jan 1, 2008 | 01:29 PM
homer j's Avatar
homer j
the turbo from an s14 will cause headaches on the FRS manifold. the reason for this is that it uses a five bolt wastegate elbow similar to the standard ERST design so cannot be rotated. as a result the wastegate housing will point at the engine. I'd just go for a good secondhand turbo from the focus rs. that way it fits, should have plenty of power there, and fabrication of the down pipe should be a piece of cake.
HTH
regards
tom
Old Jan 1, 2008 | 05:12 PM
xrt-mart's Avatar
xrt-mart
Will have to keep a look out then. I have emailed pumaspeed to see what they can offer
Old Jan 1, 2008 | 08:21 PM
woolford's Avatar
woolford
contact these asap ST ALBANS CAR CLINIC
Tel: (+44) 01727 867747
e-mail: sales@sccperformance.com
Old Jan 1, 2008 | 10:34 PM
xrt-mart's Avatar
xrt-mart
OK will do thanks
robnock
21
May 13, 2019 05:29 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
