TCA´s
Old Dec 26, 2007 | 07:47 PM
garrett-killer's Avatar
garrett-killer
Default TCA´s
hi!
are the lower TCA from 4*4 and 2wd identical?
i want to adjust my camber on the front of my escos
and dont want to use adjustable tca´s,because
they are not allowed in germany/austria.
i´ve lowered my car ~3cm with eibach springs
and want a front camber with ~1degree
does someone know if the 2wd tca is shorter than the 4*4.
or could i use a capri-escort mk3,fiesta tca?
best regards chris
Old Dec 26, 2007 | 08:48 PM
NUTS RuS's Avatar
NUTS RuS
Different fixings sorry.
The 2wd is held on with a bolt on top and the 4x4 with a bolt through the side.
Can you modify the inner mounting points ?
Or swap them back over at check time ??
Old Dec 27, 2007 | 04:26 AM
Use offset bushes, then just turn as required to the figure you want and lock off.
Old Dec 27, 2007 | 11:46 AM
garrett-killer
thank you mates!
where can i buy a set offset bushes?
i dont want to drill out my holes
best regards chris
Old Dec 30, 2007 | 02:16 PM
garrett-killer
*bump*
where can i buy offset TCA bushes?
best regards chris
Old Dec 30, 2007 | 03:50 PM
Cheapest option unfortunately is to have some made, but you would need to approach someone who would pour them out of silicone for you.
Can you not use adjustable top mounts or are these also not allowed ?
Old Dec 30, 2007 | 07:49 PM
garrett-killer
thank you for your reply,
has someone made his own TCA bushes?
aluminium is easy to drill,but could i use alu bushes
with rubber rings?
best regards chris
Old Dec 30, 2007 | 10:07 PM
NUTS RuS's Avatar
NUTS RuS
Where/how are you thinking of placing them ?
Old Dec 31, 2007 | 07:31 AM
garrett-killer
instead of the inner TCA bushes.
or should i enlarge the holes and fit
a bolt with offset washers like audi
to adjust the camber?
best regards chris
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark V8
Sep 13, 2015 09:34 AM
mint_s2
Sep 2, 2015 08:58 AM
bassboy
Aug 5, 2015 08:21 AM
