4x4 Rear Suspension on 2wd Cossie??
Hi Guys,
Just a quick question. I am building up a 3 door cossie (2wd). Back end wise I have a 4x4 saff cos rear beam and other bits lying around that are like new. It looks an easy job to convert this beam to accept a 7.5 diff, just the one bolt hole carrier needs widening where the diff is bigger, all other 5 bolt holes line up.I have already got 2wd diff and shafts. Questions are;
1, is this ok to use, has anyone had problems using this set up?
2, I presume the 4x4 wishbones are the same and okay use?
Many thanks, Ben.
Many thanks, Ben.
09-10-2015 07:38 PM
