heater problems
Old Dec 26, 2007 | 11:38 AM
Mark_'s Avatar
Mark_
Default heater problems
my father inlaw has a 1998 mondeo which only blows cold air. the air con wont turn off, the button is working so i was wondering if there is a relay for the aircon that might be faulty, if so where is it located? thanx in advance for any help
Old Dec 26, 2007 | 04:41 PM
Disconnect the wire connector on the clutch unit, this will disengage the clutch on the air con pump.
This will at least get the air con off, can't help with relay i'm a fraid but would be worth ringing FOCUS/MONDEOPART 01603 866999, as they dothese all day long.
I am a bit confused as aircon NOTHING to do with the temperature at all, you can have it on on HOT and it will be HOT, are you saying that it will not get HOT when HOT is selected on temp dial ?
If so could be a vacuum leak as the flaps are vac operated, and could be stuck in the cold position.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
