power steering
Old Dec 9, 2007 | 05:44 PM
pjdj1989's Avatar
pjdj1989
Default power steering
hi, ive been looking at buying an xr2 engine to fit into my 1.3 fiesta.
but what i was wondering is wether or not i will be able to keep the power steering or will i lose that feature?
It might be a really easy question to answer, but i just thought i had best ask!
thanks a lot..
Old Dec 9, 2007 | 05:57 PM
The problem if any would be the pump, ie if no CVH(xr2) ever had a pump mounted on it, you would need to adapt one to fit then sort out belt etc, but I am fairly sure cvh could be had with power steering so should be easy enough to find the bits, just with a bit of searching around.
Old Dec 10, 2007 | 07:51 PM
MarkN's Avatar
MarkN
Early Mk5 Escorts came with CVHs and power steering - you could rob the bits off that
Old Dec 11, 2007 | 07:18 PM
The_Fireball's Avatar
The_Fireball
I converted my XR2i to PAS. Bit difficult for parts
Old Dec 11, 2007 | 07:20 PM
The_Fireball
Oh yea, and with regards to your current engine, its an HCS i assume? That means that only the Steering rack could be kept as the pipes and all the rest mentioned above are routed totally differently, and the pump and bracket are obviously in a different place and fitting on a CVH
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
