Megasquirt
Old Dec 6, 2007 | 09:30 PM
Phil2002's Avatar
Phil2002
Default Megasquirt
has any one got any feed back on mega squirt engine managment good or bad . Thinking of using it on my zetec turbo project. Is it any good cause it's foooking cheap
Any feed back would be great thanks in advance
Phil
Old Dec 7, 2007 | 08:12 PM
JesseT's Avatar
JesseT
First thing you need to grasp is that it's a family of engine managements with many different hardware, firmware and software options. It's really good if you know which combination is best performance/buck for you.
I've been running the ~100€ kits for ~5 years and it's been perfect for me. The firmware has taken giant leeps from a few years back and it wasn't bad even then.
Old Dec 12, 2007 | 09:58 PM
Phil2002's Avatar
Phil2002
Thanks jesset
I think it's the way i'm gonna go want to try and do the hole conversion my self so the more diy it gets the better.
Think a lot of tuners get a bit greedy in the ford rs world. would rather do it my self than line the pockets of the money grabbing W4Nk3R5.
Old Dec 16, 2007 | 11:31 AM
richy3door's Avatar
richy3door
what you need to remember is that these system normally come with no map, and unless you have done so befor can be quite tricky even getting a base map right. even then you really need a rolling road to set it up 100%
Old Dec 17, 2007 | 12:53 PM
NUTS RuS's Avatar
NUTS RuS
What do you do when you get toothache ? Dentists charge a fortune too, but they invest in the right equipment to do the job right. Of course you can buy a drill and a pair of pliers and have a go yourself but the pain you end up with is often worse than paying a qualified person to sort your problem out
Old Dec 17, 2007 | 10:37 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
just got my MS 2.5 to run my super charged zetec,looks good,they give you a base map theres millions of maps on theres site to get it going to,but u can live map it if u have a laptop
Red_bull
Aug 25, 2015 06:27 PM
Matthew_M
Feb 18, 2007 09:31 AM
1.8 esc
11
Jun 22, 2006 12:48 PM
16vzetec
Jun 2, 2006 01:26 PM
Mad Professor
Jun 28, 2005 05:17 PM
