Indicators, wipers and windows stopped working at same time!
Old Nov 29, 2007 | 08:41 PM
Mullet's Avatar
Mullet
Default Indicators, wipers and windows stopped working at same time!
My windscreen wipers, indicators and electric windows have all stopped working at the same time. Its happened before but then it went ok a few hours after. But this time its just not happening. All fuses are OK. What could it be?
Old Nov 29, 2007 | 08:48 PM
McGoo 69's Avatar
McGoo 69
its a escort td btw folks haha
Old Nov 29, 2007 | 08:50 PM
Mullet's Avatar
Mullet
Oh ye forgot that bit
A knackered escort td btw!
Old Nov 29, 2007 | 10:13 PM
johnnysash's Avatar
johnnysash
escort td as in a mk5 escort? the mk 5 escort is prone for dodgy fuse boxes. drop it down from behind the dash and have a look at it. is probably covered in crud where it has got damp!
Old Nov 30, 2007 | 04:52 PM
ajjames's Avatar
ajjames
TRY THE BLACK RELAY ON TOP OF THE FUSE BOX HAD THE SAME PROBLEM ON MY COSSIE AND THAT WAS THE FAULT
Old Nov 30, 2007 | 05:12 PM
Mullet's Avatar
Mullet
Right, started working again this morning. And has now stopped working. Checked the fusebox, looks ok. Will get a realy from scrappers and try that, if no joy. Then a fusebox
Old Nov 30, 2007 | 05:48 PM
mechanic28's Avatar
mechanic28
why get a relay from a scrap yard,odds on it will be buggered not a expensive item get a new one or just test the relay with a battery across term 85 and 86 and do a continuaty test across term 30&87
Old Dec 3, 2007 | 05:03 PM
Mullet's Avatar
Mullet
Its started working again but keeps going off an coming back on. Could it really be a faulty fusebox causing it as it keeps coming back on
Old May 24, 2010 | 08:23 AM
chris_escort's Avatar
chris_escort
hi , i have the same fault, did you ever discover the cure for this???
liam-rst
Aug 10, 2015 08:46 AM
dlwarrior
Aug 5, 2015 10:19 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
