Turbo Technics cvh turbo conversion??
Old Nov 21, 2007 | 05:11 PM
rob803's Avatar
rob803
Default Turbo Technics cvh turbo conversion??
I have found a TT kit on ebay, its only missing the boost pipes.
No.1 Are they boost pipe essencial or could i make some up on the pipe bender or with hose?
No.2 Could i make this kit work with my twin 40 dcnf's if i was to fabricate a air box of some description?
Thanks rob
Old Nov 21, 2007 | 06:59 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
cant see why not, but tbh you dont need the kit if your going to fabricate your own carb box and boost pipes why not just buy a frst/erst manifold & turbo and pipe it up to your carbs.
The TT kits demand a premium due to the name and nature of component. If you have different carbs and can make boost pipes then as I say DIY it with a cvh turbo manifold and turbo running low boost (same as TT would run)
Dan
Old Nov 21, 2007 | 07:09 PM
mechanic28's Avatar
mechanic28
i used to have a xr2 turbo technics but i broke it for parts
Old Nov 21, 2007 | 07:51 PM
rob803's Avatar
rob803
so id be better to get a frst turbo and manifold, what else would i need and what else would i need to do?
rob
Old Nov 21, 2007 | 09:49 PM
iceman44's Avatar
iceman44
Default im doing
im doing the same mate i want a carb turbo set up as simple as possible
Old Nov 21, 2007 | 10:48 PM
Billy_RS's Avatar
Billy_RS
Personally i would just whack an rs turbo engine in, if you want a turbo set up.
Cant see why you would want to stay on carbs?
Old Nov 22, 2007 | 11:43 AM
SillyFezzaMk1
Rubber Rhino Crew
If you wanted to keep the twin 40's then i'd use the RST exhast manifold, turbo & intercooler.
If you wanted to sell the twin 40's and buy a normal TT compatible carb it'd pay for itself
Or bite the bullet and do a full rst conversion (fuel tank, pump, management etc... etc...)
If you want ease then i'd sell the twin 40's you have and but the TT kit and source a carb the TT kit was designed for...make up a boost pipe and your sorted.
Dan
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
Jerry Ryan
Sep 2, 2015 08:02 PM
kevin36
Sep 2, 2015 06:24 PM
