idle problem
Old Nov 20, 2007 | 04:43 PM
mechanic28's Avatar
mechanic28
Default idle problem
ok kind of strange in a way this got my car mapped at nms a couple of weeks ago karl done a top job i must say!!!! ever since she has idled abit fast around the 1100 rpm mark was not bothered at the time but it starting to annoy me.Yesterday i phoned nms explained and asked if it was ok for me to set the base idle(in case it messed with the mapping!)any way the ok was given just dont touch the co!fair enough ,so got the car nice and hot,disconnected the iscv and the idle speed did not change so this means the throttle is at is correct setting with regards to the tps i.e ecu seeing 0v,correct??? so anyway i slowed to base idle down to around 800rpm reconnected the iscv the idle picked up and settled again to around 1100rpm no matter where i put the base idle when reconnecting the iscv is sits at 1100rpm so reset the base idle to the correct position i.e when u reconnect the iscv the idle does not change any thoughts on why the idle wont change is it something to do with the map???or does the tps switch need adjusting?it should not tho as when i had my first live map earlier in the year the set the tps !any thoughts
Old Nov 20, 2007 | 07:03 PM
mechanic28's Avatar
mechanic28
upp
Old Nov 21, 2007 | 12:43 PM
mechanic28's Avatar
mechanic28
up
Old Nov 22, 2007 | 09:52 AM
grcossie's Avatar
grcossie
Try to adjust tps http://www.totenauto.no/teknisk/Sier...nosis_Info.pdf
Old Nov 22, 2007 | 12:15 PM
mechanic28's Avatar
mechanic28
cheers grcossie!
but i can not seem to poen the file can someone open it for me and paste it on here
Old Nov 22, 2007 | 01:23 PM
mechanic28's Avatar
mechanic28
ignore just spoke to karl and he mapped it at that idle speed
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
