4x4 rear driveshaft nut question
Old Nov 18, 2007 | 06:56 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Default 4x4 rear driveshaft nut question
I'm stripping down the rear beam/diff/arms/hubs etc.. on a 4x4 sierra beam and have not got a socket big enough for the drive shaft nut. Can anyone tell me the size as I measured it up at 40 (i think dont quote me) but went to Halfrauds and they don't go that high but they do an imperial size thats very close to the size I need....
Anyone?
Dan
Old Nov 18, 2007 | 07:00 PM
andrewg's Avatar
andrewg
i'm sure its 41
Old Nov 18, 2007 | 07:01 PM
dojj's Avatar
dojj
Resident Wrestling Legend
41mm
left and right hand threaded too
Old Nov 18, 2007 | 07:02 PM
dojj's Avatar
dojj
and yes they should do as i saw one of them the other day in halfrods
the other thng to remind you is that the shafts are sided for length so don't get them mixed up otherwise you may find that they hit in the inner parts of the cv joint as the suspension travels upwards
Old Nov 18, 2007 | 07:03 PM
andrewg's Avatar
andrewg
or 1" 5/8 i think
Old Nov 18, 2007 | 07:10 PM
SillyFezzaMk1
Rubber Rhino Crew
Originally Posted by andrewg
or 1" 5/8 i think
Can you confirm this cause the local halfrauds to me did have this and not the 41 I need
Old Nov 18, 2007 | 07:39 PM
RichieST's Avatar
RichieST
41mm is 1.61inches, so 1" 5/8 sounds about right
Old Nov 18, 2007 | 08:12 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
and you WILL need air tools to get em un done if theyve not been off before lol
Old Nov 18, 2007 | 08:15 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
or 1" 5/8 i think
I have one that you could borrow overnight..
Old Nov 18, 2007 | 08:16 PM
SillyFezzaMk1
Rubber Rhino Crew
yeah I thought as much!...
I've made a right booboo as the rear arms are off of the beam and the inner flange of the shaft unbolted from the diff so basically I have no real way of holding the shaft from spinning whilst I undo the nut might have to get them in the boot and down to the local garage and get the gun on them like you say
Cheers Fellas
Dan
Old Nov 18, 2007 | 08:21 PM
CosKev3's Avatar
CosKev3
My m8's Dad made this,works a treat
Makes it a one man job to undo/tighten them
Old Nov 18, 2007 | 08:22 PM
dojj's Avatar
dojj
if the beam is on the car you can put an old steel rim on and then use the wieght of the car to stop it from turning while you undo it
if it's off then what you need to do is put an old brake disc on there and then find something to bolt to the hub carrier to stop the disc from turning
you'll need a vented disc as you can jam a screwdriver into the spokes, unles you've got vented rear discs then you an just put the cossie rear caliper carriers on and use them
just make sure you have someone standing ont he beam while you undo it as the last one i did needed the nuits cut to almost the threads then my dad standing on it, all 16 stone of him AND 300 ft/lbs on 4 foot worth of 3/4 drive socket to undo the nuts, and this was before i figured out i was turning them the right way as well
SillyFezzaMk1
Rubber Rhino Crew
or 1" 5/8 i think
Rear arms are off the car so if you dont mind me nipping up to your place Sat i'd be very grateful.
Dan
Old Nov 18, 2007 | 08:23 PM
NEEDFORSPEED
what a great idea! well done that man!
Old Nov 18, 2007 | 08:27 PM
Martin-Hadland
or 1" 5/8 i think
Dan
No problem, we wont need to use a gun... We have a technique
Old Nov 18, 2007 | 08:29 PM
SillyFezzaMk1
Rubber Rhino Crew
ok do you need the calipers and disks on the hub? as its bare atm
DAn
Old Nov 18, 2007 | 08:31 PM
Martin-Hadland
DAn
No, fine as it is.
Old Nov 18, 2007 | 08:44 PM
SillyFezzaMk1
Rubber Rhino Crew
Brilliant! See you Saturday then....
Dan
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Caddyshack
Aug 19, 2015 07:29 PM
Bosch
Aug 4, 2015 05:14 PM
Old ford
Jul 31, 2015 06:50 AM
