Fiesta Heater Blowing Cold
Old Nov 16, 2007 | 04:33 PM
fordnut's Avatar
fordnut
Default Fiesta Heater Blowing Cold
Got a right pain of a problem with my sisters R reg Fiesta.
It will only blow out cold air no matter what position i set the knob to.
I have tried changing the control panel, and there is hot water going in and coming out of the matrix so that isnt blocked.
Has anyone else come across this problem?
Old Nov 16, 2007 | 07:21 PM
o n i o n's Avatar
o n i o n
I would but money on it being your heater control valve on the bulk head,
They are quite common, make sure you get the latest one available or you may get over heating and bleeding probs, as some of the early ones were faulty.
The fact both pipes (in and out) are hot, is probably just radiation.
HTH.
Old Nov 17, 2007 | 04:39 PM
blackerst's Avatar
blackerst
we had a car in work with the same problem turned out to be the heater control panel as there electric on these
Old Nov 17, 2007 | 06:24 PM
dave green's Avatar
dave green
Defo be that valve £35 from fords
Dave
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
