ERST DUMP VALVE
Old Oct 8, 2004 | 04:33 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Default ERST DUMP VALVE
Hi im currently using the bailey piston dumpvalve with no problems at all, but the other day i heard a erst with a different sounding dump valve like a rally car one like a chatter sound instaed of pissstttttt!!, i know the bailey one wot i have is ok and the best for idleing problems but its bugging me on which dumpvalve it was, and it werent a efi engine in it either!!.
Thanks
Old Oct 8, 2004 | 04:39 PM
AKRS1's Avatar
AKRS1
should have had an efi engine in it. Thats usually the sound of the wastegate shutting i think as someone mentioned on this site sometime ago. You dont get the sound in ERSTs because something to do with the metering unit i think. I think thats what it is
Old Oct 8, 2004 | 04:54 PM
GrimmeRS2K's Avatar
GrimmeRS2K
its deffo a erst engine coz i know the bloke who put in then he sold the car the other day, and it appeared the other nite with that sounding dumpvalve!! or wastegate thingy!!
Old Oct 8, 2004 | 07:54 PM
b13nde's Avatar
b13nde
na sounds like waste gate escorts do it some times but you have to drive slow no road noise and depending on how its set up you mite hear it butvery fant
Old Oct 10, 2004 | 06:04 PM
D7AKE's Avatar
D7AKE
I have a forge motorsport dump valve and I have both chatter and woooooosh on my S2 running 220bhp tho....
Old Dec 21, 2004 | 02:13 PM
turbo stealth's Avatar
turbo stealth
i have a stage 3 hybrid and no dump valve and the chatter is quite loud for s2
Old Dec 21, 2004 | 02:29 PM
bud-weis's Avatar
bud-weis
Football Cwazy
the chatter sound is from the compressor wheel stalling as the air is forced back through it when you lift off ( it has nowhere else to go with no dump valve ) . you can hear this noise coming from the induction kit. as far as i know you shouldn't get it on an mfi car as the flap inside the metering unit will close when you lift off,
Old Dec 21, 2004 | 04:11 PM
ColinRS's Avatar
ColinRS
I hav a LeManns Dump Valve on my S2 which does the usual bus psssshhhht, but when i bout a bailey twin piston DV, and when i fitted it it made a funny noise when it dump instead of the pssssssshht , so i took it back off
Old Dec 22, 2004 | 09:05 PM
big_wig_074's Avatar
big_wig_074
unless he removed the hose from the turbo to metering unit!!!some1 once told me this was the way to do it!!! soon told him the error of his ways!!!! jesus,u have to be mad to do that!
Old Dec 24, 2004 | 01:27 PM
turbo stealth
if you done that on a s2 it would not even run
Old Dec 24, 2004 | 01:30 PM
GrimmeRS2K's Avatar
GrimmeRS2K
as if ur selling the stealth rob
Old Dec 26, 2004 | 04:44 PM
turbo stealth
yep im goin japanese now ,i need a change from fords for a while
Old Dec 26, 2004 | 05:53 PM
111's Avatar
111
i took the bailey dump valve off my girlfriends series one and the wastegate chatter is very loud its running 16 psi if that helps
Old Dec 27, 2004 | 10:23 AM
GrimmeRS2K's Avatar
GrimmeRS2K
rob, bet ur gonna get one of those starlet gt turbos whats on your garage!
Old Dec 29, 2004 | 07:50 AM
turbo stealth
nope ,mr2 turbo or a pulsar gtir , havent decided yet
Old Dec 29, 2004 | 08:14 AM
a/rs/e's Avatar
a/rs/e
Just breezing through might have a TurboSmart external wastegate fitted. This along with their Supersonic dumpvalve leaves an impression.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
