Cossie Managment Question
Old Nov 9, 2007 | 09:23 PM
B19LRW's Avatar
B19LRW
Its Broken.....
Default Cossie Managment Question
the wife has a cossie managed FRST, and its got a annoying judder/ misfire at 2800rpm. how do i gap the sensor on the bottom pulley?
as im running outt ideas!
Old Nov 9, 2007 | 09:27 PM
JjCoDeX75's Avatar
JjCoDeX75
IIRC this has to be at 0.8? Please someone correct me if I am wrong
Gap as you would any other sensor - loosen bolts, get gap right and then tighten up (gap between 4 pickups and sensor)
HTH
JJ
Old Nov 9, 2007 | 09:30 PM
B19LRW's Avatar
B19LRW
Its Broken.....
thanks! JJ, would that cause the symptoms?
Old Nov 9, 2007 | 09:36 PM
Jay,'s Avatar
Jay,
Sponsor
if its incorrectly gapped it will cause a miss fire
Old Nov 9, 2007 | 09:38 PM
B19LRW's Avatar
B19LRW
Its Broken.....
Jay & JJ. I thank You.
Old Nov 9, 2007 | 09:39 PM
JjCoDeX75's Avatar
JjCoDeX75
NP Best of luck with it - also check plugs
JJ
Old Nov 9, 2007 | 09:42 PM
B19LRW's Avatar
B19LRW
Its Broken.....
JJ
it had new plugs and leads less than 300 ago!! but cheers!
Old Nov 9, 2007 | 09:45 PM
Jay,'s Avatar
Jay,
Sponsor
has it got a converted cossie dizzy on it to ? if so gap the phase sensor to
Old Nov 9, 2007 | 09:47 PM
JjCoDeX75's Avatar
JjCoDeX75
I dont know much about FRSTs to be honest, only cossies. But in the cossie land the other critical part of the equation is the Phase Sensor. Sepcifically, the wires in the sensor tend to break down.
Now on a cos, it is located on the distributor (under the cap). Dont even know if the RST uses one but it will need some form of cam timing input. If there is, also check that it is gapped properly - I think the manual says betweeen 0.2 - 0.3
JJ
JjCoDeX75's Avatar
JjCoDeX75
Great minds think alike Jay! Beat me to it! LOL
JJ
Old Nov 9, 2007 | 09:50 PM
Jay,'s Avatar
Jay,
Sponsor
Old Nov 9, 2007 | 09:52 PM
B19LRW's Avatar
B19LRW
Its Broken.....
yes it does have a 'lashed' dizzy. i will check that tomoz!! im seriously thinking of converting to ofac. less hassle!!
Cheers!!
Old Nov 9, 2007 | 09:54 PM
Jay,'s Avatar
Jay,
Sponsor
not a bad idea lennie if it is a lash up !
still dont get it why people pay a small fortune to have webber management put on a rst/frst
Old Nov 9, 2007 | 09:56 PM
B19LRW's Avatar
B19LRW
Its Broken.....
i bought the car with it 18mths ago and its done.... 300 miles! Ofac is fine ( for her!) i think that weber managment should stay on a cossie too!!
i mean FFs all she want to do is paint it pink and put stars up it!!! (serious!)
Old Nov 9, 2007 | 09:57 PM
Jay,'s Avatar
Jay,
Sponsor
right lock her in a fuckin seller and sell the car
Old Nov 9, 2007 | 09:59 PM
B19LRW's Avatar
B19LRW
Its Broken.....
fuck that. you seen the size of my missus! im 23 stone and 6 ft and she scares me! lol
Old Nov 9, 2007 | 11:07 PM
EssexMikeSi's Avatar
EssexMikeSi
u can see why i gave up and decided to sell the lot now cant ya lennie. Yes mfi's crap, but least i pus every garage around will be familiar with a standard rs turbo set up, instead of trying to explain what uve done with a cossie dizzy lol
Old Nov 9, 2007 | 11:25 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
why not convert it to run coil pack got to be more simple than a lashed up dizzy ?
Old Nov 10, 2007 | 10:22 AM
Stu @ M Developments's Avatar
PassionFords Creator
Sorting your CPS to PPS syncronisation would seem a better bet.
Old Nov 10, 2007 | 11:28 AM
B19LRW's Avatar
B19LRW
Its Broken.....
can i have that in 'Lennie' language! CPS i understand to be crank position sensor but PPS?
Old Nov 10, 2007 | 11:31 AM
JjCoDeX75's Avatar
JjCoDeX75
I think that PPS would be Phase Position Sensor(Stu?)
JJ
Old Nov 10, 2007 | 11:42 AM
Correct Sir.
Old Nov 10, 2007 | 11:46 AM
B19LRW's Avatar
B19LRW
Its Broken.....
and that is done how? i cant drive the fooker and its doing my nut in.
Old Nov 10, 2007 | 11:55 AM
JjCoDeX75's Avatar
JjCoDeX75
Is the Phase sensor in the dizzy like the cos? If so, then it is basically a magnet. You can undo one of the screws and adjust with feeler gauges.
Sadly I know nothing of the non cossie stuff!
JJ
Old Nov 10, 2007 | 12:01 PM
B19LRW's Avatar
B19LRW
Its Broken.....
yeah. i have got a good idea! im gonna burn the cunt!! lol
Old Nov 10, 2007 | 12:05 PM
JjCoDeX75's Avatar
JjCoDeX75
Probably easier in the long run! LOL
JJ
Old Nov 11, 2007 | 01:04 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
CPS gap = 0.8
PPS gap = 0.3
Dizzy also needs rotating so that the rotor arm points to the groove in the dizzy body.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
BRAM
Sep 8, 2015 07:11 AM
