noisey cam and tappets
Old Nov 9, 2007 | 08:03 PM
musicman1's Avatar
musicman1
Default noisey cam and tappets
hi everyone my little escort has got a noisey top end tapping and rumbling but gets quiter when warm will a new cam and tappets sort this out thanks rob[img][/img]
Old Nov 9, 2007 | 08:23 PM
lukemakepeace's Avatar
lukemakepeace
you can get treatment for the tappets, its like an oil additive, you put it in the engine, run it for X amount of miles then drain it and put normal oil back in. worked for my mates mazda 323f.
Old Nov 9, 2007 | 09:12 PM
Is it a cvh engine mate. If so you can get a tappet set which are about 50 quid for the 8 tappets.you can buy a special tool which i have. To replace these you can use this tool and you dont have to take the head off to do these. I had mk4 escort xr3i and i changed tappets on both of these.
Old Nov 10, 2007 | 09:20 AM
antony215's Avatar
antony215
Escort Rs Turbo
Theres no point changing just the tappets you need to change the cam aswell as they ware togethere. If you change just the tappets they will go again get a cam and tappets set and do it right the first time round.
Old Nov 10, 2007 | 08:28 PM
Or right well like i said when i had my xr3s i just changed the tappets and i had both cars over 2 years and they were ok.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
