Mapping with a Wideband..
Old Nov 8, 2007 | 09:48 AM
SapphyMike's Avatar
SapphyMike
Default Mapping with a Wideband..
I think I know the answer to this....
but.
Mapping a car - should it be done purely on the results of a wideband reading?
Old Nov 8, 2007 | 09:52 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
How are you going to map ignition?
with regards to fuelling though, wideband gets you to where you *think* the car wants to be, ie "I reckon 11.5:1 at 2 bar of boost is a good starting point"
Ideally though, you would then look at EGT's as well, like for example Stu was saying Focus RS need to be a lot richer than a cossie in the same circumstance, so you need to be monitoring other things to know that.
Old Nov 8, 2007 | 09:56 AM
foreigneRS's Avatar
foreigneRS
Testing the future
it also doesn't tall you that you are getting the best torque that you possibly could - only that you are in the right area
imo, only a dyno can do that entirely accurately. although by using a g-meter (or just a time/distance measurement) on a repeatable stretch of road to measure acceleration can give you some idea
Old Nov 8, 2007 | 09:59 AM
lead_foot's Avatar
lead_foot
is awesome
"Off topic" Any idea why?
SapphyMike's Avatar
SapphyMike
i thought this would be the case.
Cheers for clearing that up!
Old Nov 8, 2007 | 10:03 AM
foreigneRS's Avatar
foreigneRS
Testing the future
restrictive exhaust manifold
Old Nov 8, 2007 | 10:08 AM
Chip's Avatar
Chip
Although experience of a very similar spec engine can do that
Im sure most of the guys on here mapping cossies for example, know full well what AFR's are going to work on which spec without needing the dyno again and can get ridiculously close to ideal results just from experience/AFR
lead_foot's Avatar
lead_foot
is awesome
CheeRS Nick
Old Nov 8, 2007 | 10:12 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i agree - if the spec. is known in detail.
but i suspect the topic starter is asking as he wants to do it himself and doesn't have that experience to rely on
Old Nov 8, 2007 | 10:13 AM
Chip's Avatar
Chip
Now YOU are making assumptions
He is actually asking because its what someone else has told him that he does, and he was unsure as to wether that was sufficient (I know as Ive just been chatting to him on MSN about it )
Old Nov 8, 2007 | 10:23 AM
foreigneRS's Avatar
foreigneRS
Testing the future
no, i suspect. not i assume
Old Nov 8, 2007 | 10:26 AM
Chip's Avatar
Chip
Your suspicion was based on an assumption I suspect
Old Nov 8, 2007 | 10:36 AM
SapphyMike's Avatar
SapphyMike
however, I am shorty going to be looking to ruin a cavalier sri 2.0 with megasquirt to start me on the slow learning curve to maybe know something about stuff
Old Nov 8, 2007 | 10:40 AM
Jay,'s Avatar
Jay,
Sponsor
wideband
egt gauge
det cans
is what i use
Old Nov 8, 2007 | 10:51 AM
SapphyMike's Avatar
SapphyMike
what stuff do you use Jay if you dont mind my asking?
Old Jul 19, 2008 | 12:00 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
chip how do you go about setting up the ignition map? its mike btw we met the other day
Old Jul 19, 2008 | 12:29 AM
Chip's Avatar
Chip
You put in values you think will be safe as a starting point (based on experience) then you get the AFR's right, then you increase the ignition until you hear det, then you come back a few degrees.
Thats how you do a basic live map anyway.
Things like minimum advance for best torque need rollers, although generally taking timing out till the heat increases (if you have an EGT probe and can hold it on the brakes or similar to load it on a cell for a long time) gets similar results as normally as you move from min advance for best torque you also see an increase in temp
Old Jul 19, 2008 | 07:31 AM
Just one of the reasons why a rolling road is better than a live map, you can control every situation and hold under any load any speed any gear, can't do that on the road.
Once mapped though you could run purely on egt, so long as you don't make any changes.
Old Jul 21, 2008 | 09:11 AM
clarke5700's Avatar
clarke5700
hummmm sounds good thanks
Old Jul 21, 2008 | 10:08 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You can control very little on a rolling road. Sure, you can get steady-state rolling roads now which allow you to hold the engine at a target rpm but it's not a touch on an engine dyno.
I've been quite successfully able to hold an engine at a given speed and load on the road as i'm sure most professional tuners have/do...
I think you'd be insane to rely purely on EGT. As with everything, you need as many sources of information as possible to decide what and when there is a problem - relying on one sensor can lead you down the garden path.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
jay030787
Sep 25, 2015 01:38 AM
