what year s2 ecu
Old Oct 4, 2007 | 05:26 PM
thomason's Avatar
thomason
Default what year s2 ecu
hi all, i'm just wondering what year s2 the blue, red and black stickered ecu is from.
I read on here somewhere the other day that if you had a 90 spec ecu on a 88 spec engine it would retard the ignition and it was due to a knock sensor.
Can anyone shed some light?
Cheers.
Old Oct 4, 2007 | 09:05 PM
dave cos4x4's Avatar
dave cos4x4
iirc the hearts and diamonds were on the later cars,i think.
Old Oct 5, 2007 | 06:42 AM
MorryRS's Avatar
MorryRS
As above . 90 spec cars should be Hearts and Diamonds then there is a few options for older cars
Old Oct 5, 2007 | 01:12 PM
SafeChav's Avatar
SafeChav
Not been on much lately and ive forgotten the colours
If you have what is actually an ecu off an 88 spec car its fine on a 90 spec, the only times you cause problems are fitting 87 onwards spec ECU's into 86 and earlier cars because they dont have a knock sensor wired in so the ignition runs permenantly retarded.
A series 1 ECU is actually the best ECU you can get as long as you have your car set up so theres no chance of detonation.
99.9% sure BLUE RED BLUE & BLUE RED WHITE are S1 ecu's so yours is a S2 ECU
162
Dec 25, 2019 09:43 PM
big_Rad
Sep 15, 2017 09:36 AM
3drRich
Sep 13, 2015 07:32 PM
ekjim
Aug 17, 2015 08:57 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
