cossie is ratlling a bit when is cold.
Old Sep 10, 2007 | 05:02 PM
turblower's Avatar
turblower
Default cossie is ratlling a bit when is cold.
hallo peeps...i bought my first cossie about 1 month ago,i drove it a few times and did a oil changhe on it.(i bought the right oil for it)it has started to to make a noise like a tikking noise,it comes and goes when is cold,but when its warm the noise stops.
maybe it could be the tappets,camshafts.etc?
Old Sep 10, 2007 | 05:06 PM
BIL N KEL's Avatar
BIL N KEL
its your lifters (tappets) there easy enough to change
Old Sep 10, 2007 | 06:27 PM
Does indeed sound like a dicky lifter or two, so try some hydraulic valve lifter lube first if not try new tappets.
Old Sep 10, 2007 | 06:57 PM
Yeh i wud of said tappets my cossie does it when cold to. Where can you get the lifter lube from and how much does it cost. I bought so new tappets months ago but i think they are cheap ones. Ive spoke to a few people and they said if i fitted the cheap tappets they would just start to rattle again in a few months.
Old Sep 10, 2007 | 07:02 PM
boost mad's Avatar
boost mad
if its a 2wd it could be piston slap
Old Sep 11, 2007 | 12:06 PM
SortedCossie's Avatar
SortedCossie
my small turbo escort randomly does this when cold, depending on how long its stood - i've been told one of the followers is loosing its oil and takes a minute or two to re-fill.
I'll prob change them over the winter.
Old Sep 11, 2007 | 12:21 PM
KSA-Cossie's Avatar
KSA-Cossie
What oil did you use m8 ? Mine does that in the colder weather too.
Old Sep 11, 2007 | 01:14 PM
Cheap tappets will rattle, all the time, after a few months.
Piston slap is a knocking sound, like a dull thud, best oil is a top synthetic, 15W/50 is best.
Tappets are available from Matt Lewis 01922 692424, he sells the GENUINE ones which are INA, I recently fitted a set from him myself, and it is SILENT, whether stood a week or fully hot, no noise at all.
Old Sep 11, 2007 | 02:15 PM
turblower's Avatar
turblower
thanks for the help peeps..ill have to have a go at changhe them soon...
ohh yeah the oil i used was fully synthetic 15W/50..
many thanks
Old Sep 11, 2007 | 07:39 PM
How much are them tappets then tabetha. Are they about 10 quid.
Old Sep 12, 2007 | 05:30 AM
NO they are about 10X that amount!!
I assume this is a typo on your part, they should be under a ton anyway, from memory about Ł70/80.
Old Sep 12, 2007 | 06:42 AM
Or thats not 2 bad will have 2 get some of these.
Old Sep 12, 2007 | 11:04 AM
Spoke to Matt L today and he has only ONE set left at the mo(selling well).
Matt Lewis 01922 692424.
Oct 9, 2015 07:38 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
The Enigma
13
Aug 20, 2015 09:38 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
