Water Pissin Out!!!
Old Jan 18, 2004 | 06:44 PM
Default Water Pissin Out!!!
I have a water leak on my cossie, thought it was the head gasket but now believe it is a pipe under where the injectors are. Right hand side of block somewhere round the oil filter area. Does anyone know if this is a bugger to get to, i'm not very good at mechanics, is it best to take it to a garage, don;t really want to drive it whilst it's pissin out. is it easy to fit and what the pipe is called (part no if poss)
Your help and advice and instructions on replacement of this pipe would be very useful and appreciated!!
Thanks Bison (Newbie)
Old Jan 18, 2004 | 06:49 PM
kjc300's Avatar
kjc300
There's two round there, and it's a bit of a bugger but easier if you take the dizzy cap and leads out the way!! someone will probably have a look on microcat for you!! I can't - formatted my laptop not put it back on yet!!
Old Jan 18, 2004 | 06:55 PM
What microcat? soryy new to all this!!
Bison
Old Jan 18, 2004 | 07:05 PM
kjc300's Avatar
kjc300
The same thing ford parts department have to look up parts on!!
Old Jan 18, 2004 | 07:06 PM
So do you think an idiot could replace it without 2 many probs? I have a socket set.
Is it worth getting uprated hosing as I am replacing it anyway?
Bison
Old Jan 18, 2004 | 07:31 PM
stevedohc16v's Avatar
stevedohc16v
As kev says it could be one of your oil cooler hoses which are just above your oil filter next to the block, have a look round that area to see if you can see them leaking, if you want new ones from Ford the finis codes are 1639256 for the forward most one or 1643728 for the rearmost pipe. They are fiddly to change but only because of the tight space you have to get a screwdriver in to the jubilee clips.
Steve
Old Jan 18, 2004 | 09:31 PM
i just had to replace a pipe that comes off the water pump this week ,had to get an escort cosworth pipe as ford dont make the sierra cosworth pipe any longer.
Old Jan 19, 2004 | 09:16 PM
thanks for your help, now sorted!!
Old Jan 19, 2004 | 09:22 PM
kjc300's Avatar
kjc300
What was it mate????
Old Jan 21, 2004 | 07:42 PM
twas the front oil cooler pipe.
Old Jan 21, 2004 | 07:50 PM
Sorry this is off topic but is it possible to get hold of a copy of microcat and if so where
Old Jan 21, 2004 | 08:41 PM
i have one ,bought it on ebay
Old Jan 22, 2004 | 12:38 AM
PJay's Avatar
PJay
I will say NO, microcat is a commercial product and it's sale or resale is an infringement of microcats copyright, there are copies out there!
PJay
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
