Replacing RST rear wheel bearings????
Old Sep 3, 2007 | 10:53 AM
Blakeya's Avatar
Blakeya
Default Replacing RST rear wheel bearings????
I need to change the rear wheel bearings on my RST & would like to know the answers to the following questions as i can't lay my hands on the haynes manual.
Rear hub nut size??
Are the hub nuts handed thread, left & right??
Tightnening torque when fitting new bearings??
Type of grease to use for new bearings??
All help much appreciate as would like to do the job tonight!!
Best Regards
AndyB
Old Sep 3, 2007 | 11:16 PM
SafeChav's Avatar
SafeChav
nut size - 32mm i believe
Both threads are normal opposite threads.
Tightening sequence is something like tighten the nuts to 40Nm, then slacken them back off and tighten them as tight as you can WITH YOUR FINGERS!!!! and then fit the castle nut and split pin.
LM Grease should be fine, but any decent bearing kit should have grease with it anyway.
malkiemac3579
Jul 14, 2017 12:10 PM
Chas
Sep 21, 2015 08:57 PM
dlwarrior
Aug 5, 2015 10:19 AM
Bosch
Aug 4, 2015 05:14 PM
muz
Aug 1, 2015 06:48 AM
