Sound deadening
how do you get all that crap stick on sound deadening stuff off from the inside of the car.
its on a saph cossie if it makes any odds.
cheers
cheers
flat screw driver or something similar but not too sharp as can damage or make holes on body, get a nice sized flat head and chisel it all out, takes time but when you get the hang of it you learn your oun way and it comes out quite fast.
when you finally finish use sand paper or wet and dry to get the rest of the small sticky bits off.
makes it so much lighter, just feel the weight of it all in the rubbish bag after!
hope it helps. its one of those just get in and do it jobs even though its crap!
-TRY A SOLVENT(NOT TURPS) AND A 2INCH SCRAPER--(KEEP WINDOWS OPEN FOR VENTILATION THOUGH!!!!!!!!!!---------------------------------------------------------FLAT SCREWDRIVER!!!!!!!!!!HA-HA-----------MAINS TESTER TYPE??? F---G FUNNY ON THIS FORUM!!!!!!!!!!!!!! THE ANSWERS YOU READ!!LOL
wtf are you on aron? its the way to do it. dont write things like that there is no point, this room is to HELP people, and sorry to say i am right!
may be other ways but this is by far the cheapest. hmph
Originally Posted by SafeChav
uh oh looks your guna get your finger nails dirty Alex. If its really shit you may even break some
how you doing anyway mate ?
Originally Posted by dannyboyrs
just donel my s2 used a heat gun and heated it up and comes off a doddle then wet and dry after that !!! hope thats some help
im alright man you
The easiest way mate is to get a blunt chisel and just crack the stuff, and it will just come off in pieces. If you start heating it up it goes all gooey and horrible
tried the screwdriver and hammer way and took over an hour to do a piece no bigger than 1ft x 1ft..
used a heatgun and did the same sized patch in under 20 seconds.. once the sticky crap left over has cooled down a bit of wet n dry will get rid of it no problem
well, i started with a smallish flat head screwdriver and it worked realy well, took about 15 minutes to do the bit under the back seats, then another 15 with a cloth and white spirit to get the rest of the shit off.
proceded today to do the floor pans. all i can say is after i had removed the carpet and underlay its obvious some cock has used the floor as a jacking point
but never the less got most of that off today.
can belive howmuch noise comes through the crumple zone tho, may have to cover it up...
