Lambda sensor question
Old Aug 22, 2007 | 11:03 AM
Ken_ZS's Avatar
Ken_ZS
Default Lambda sensor question
i fitted a milltek 4-2-1 on my zetec s at christmas and when lengthing the lambda i crimped the wires hoping this would b good enough. now it never run right, wouldnt idle and if i put any throttle down revs would drop to around 300rpm and it would jus about stay runnin. i unplugged it and bein lazy its been like that since!
should i have soldered the wires? i didnt put any sealer on it either which was stupid lol but i was in a rush to get 2 brighton for a christmas party.
the lambda is a fuel parts copy but i think they make them for ford so that shouldnt b a issue! might extend the old 1 and try it on it as i replaced it without reason ages ago lol
cheers ken
Old Aug 22, 2007 | 12:17 PM
sailorbob's Avatar
sailorbob
A couple of things are at play here;
Firstly, your connections will be affecting the readout. The output from a lambda sensor isn't very large and a poor connection will not help.
Secondly, the ecu calculates the time from when a change is made to the fuelling until the sensor 'sees' this fuelling change and if you move the position of the sensor then the results get screwed up. You should, if you want the ecu to do work properly, modify a table in the code to let the ecu know about the position alteration.
Old Aug 22, 2007 | 12:37 PM
Ken_ZS's Avatar
Ken_ZS
see pumaspeed dont tel ya this! think il jus keep goin with it til i put the new engine in
im gonna solder it up and make the wire as small as possible and gum it in
cheers dude
Old Aug 22, 2007 | 01:21 PM
sailorbob's Avatar
sailorbob
I expect you'll see an improvement when you solder it
There is another possibility, maybe the sensor is no good but this is doubtful if it's new.
Old Aug 22, 2007 | 01:34 PM
Ken_ZS's Avatar
Ken_ZS
im gonna try the ford 1 and this new ish 1
jus gotta dig the soldering iron out lol and stop the rain!
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
Si B
Sep 12, 2015 06:49 AM
