Anyone with early ford without wing repeaters!
Old Aug 20, 2007 | 01:54 PM
o n i o n's Avatar
o n i o n
Default Anyone with early ford without wing repeaters!
Hi peeps.
Doing a bit of a resto on a mates S1.
we have got rid of the wing repeaters in order to clean up the inner wing,
Now the indicators are flashing a bit too quickly.
Does anybody know the part number or type of flasher relay I could use to slow them down?
Thanks,
Gareth.
Old Aug 20, 2007 | 01:56 PM
If you get a universal "camping", type relay these are elctronic so speed will be correct.
Old Aug 20, 2007 | 02:05 PM
o n i o n's Avatar
o n i o n
Cheers tabetha, but a little confused,
Do you mean like a split charger relay?
Sorry
Old Aug 20, 2007 | 04:18 PM
Alvyn's Avatar
Alvyn
wont it need side repeaters for the mot then?
Old Aug 20, 2007 | 04:50 PM
o n i o n's Avatar
o n i o n
Depends on the vehicles date of first use. This car is early enough to not need them.
Old Aug 21, 2007 | 09:38 AM
NO UNIVERSAL FLASHER RELAY, often reffered to as camping/trailer relay.
As it is ELECTRONIC(make sure it is) it keeps the same flash rate irrespective of load, ie whether you have two extra lights(trailer) or not on the car.
Bosch/Hella do them, you can get them from loads of places, look in yellow pages under car electrics, the sort you need is ELECTRONIC the sort YOU HAVE at the moment is ELECTRO MECHANICAL.
ps if you have probs getting one get back to me.
Old Aug 21, 2007 | 10:13 PM
o n i o n's Avatar
o n i o n
Thanks Tabetha. Star man.
Should have posted earlier however.
Went to look at the car and ended up just being a poor earth on both side rear clusters.
Should have known really.
Cheers.
Kyle Langford
27
Aug 5, 2019 07:54 PM
borboyous
Aug 22, 2015 11:17 AM
Sultzi
12
Aug 16, 2015 01:08 PM
BMROVAL
Shows & Track Days
Jul 31, 2015 05:32 PM
