No fuel at the injectors
Old Aug 16, 2007 | 09:50 AM
japslayer's Avatar
japslayer
Default No fuel at the injectors
Can anyone help? there is pressure in the system but nothing coming from the pipes to the injectors. does the system need to be blead? its happened after a lenghty resto so could something be seized?
Old Aug 16, 2007 | 10:32 AM
grsford's Avatar
grsford
what car is it on? does the fuel pump prime?
Old Aug 16, 2007 | 10:49 AM
japslayer's Avatar
japslayer
its on a 16i, yes fuel pump primes and works fine, fuel is getting to the distributor but not the injectors
Old Aug 16, 2007 | 11:25 AM
Try unjamming the air flap!!
Old Aug 16, 2007 | 11:39 AM
japslayer's Avatar
japslayer
air flap is fine, seems to be the piston in the middle of the distributor block that isn't moving as freely as it should. are these serviceable?
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
cos elle
Sep 16, 2015 06:37 PM
tib2220
Sep 14, 2015 12:33 PM
