RS1600i fuel pump
Old Aug 11, 2007 | 03:21 PM
japslayer's Avatar
japslayer
Default RS1600i fuel pump
Having very nearly completing the resto on my 16i iv come across a set back, the fuel pump aint working! it works off a battery but not off the loom. iv checked the usual things like connections and earths so can anyone in here help?
Old Aug 11, 2007 | 03:51 PM
jon@work's Avatar
jon@work
trace back from the pump and find where the 12V supply is interrupted
will probably just be a dodgy fuse or relay
Old Aug 11, 2007 | 04:05 PM
japslayer's Avatar
japslayer
i have done, the 16i had a special relay fitted tho. it doesn't appear to be energising at all, all the power connections seems to be fine
Old Aug 11, 2007 | 04:50 PM
I had a mk4 xr3i which wudnt start n it was the fuel pump relay.
Old Aug 11, 2007 | 05:16 PM
jon@work's Avatar
jon@work
so if the relay has got 2 12V feeds to it, then it's either :
1. the relay's had it
2. there's an earth missing
3. the wiring is damaged and won't pass the current required
Old Aug 11, 2007 | 07:38 PM
japslayer's Avatar
japslayer
anyone got a spare 16i relay to try?
or sell? i know they are like hens teeth now!
can i just remind people that the 16i is different to any other ignition system and the if anyone knows how to get round the relay please post it!
Old Aug 11, 2007 | 09:03 PM
MarkN's Avatar
MarkN
IIRC a Mk1 Golf GTi relay is exactly the same and still available from VW
Old Aug 12, 2007 | 07:03 AM
I think they have a timer/prime feature don't they, these k jet stuff ?
Old Aug 13, 2007 | 10:28 AM
japslayer's Avatar
japslayer
i have whipped out the trusty multi meter and discovered the relay is faulty, does anyone have 1? what is the VW part number? yes tabetha its the K Jet system
CheeRS
Old Aug 13, 2007 | 06:28 PM
Wardy257's Avatar
Wardy257
The relay (pink, 5 pin) will not work without a feed from the coil. Do you have this?
Old Aug 13, 2007 | 08:08 PM
japslayer's Avatar
japslayer
Its a black siemens relay with a 16 amp fuse on the top of it, i can now bypass it but its not safe to run the car that way
Old Aug 13, 2007 | 09:53 PM
Wardy257's Avatar
Wardy257
How many pins? What are the pin numbers?
Old Aug 14, 2007 | 11:06 AM
japslayer's Avatar
japslayer
starting from the top right 31 brown earth, 30 red live, 31b/1 blue live (to 1 of the coils), 87 red/black (output of the relay(not working)), 15 red live
Old Aug 14, 2007 | 04:29 PM
japslayer's Avatar
japslayer
to help clarify what im on about here are the 2 different relays, the pink is the 1 that is found on the other fords, the black is the 16i relay
Old Aug 14, 2007 | 05:43 PM
Wardy257's Avatar
Wardy257
So is the feed from the coil working? You can test it with an LED test light or Noid light.
Old Aug 14, 2007 | 07:25 PM
Barry R's Avatar
Barry R
I threw a couple of them away just the other week
wasnt sure what they were for sorry
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
