NA 2.0l 16V Zetec Engine into S2 RSTurbo?
Hi,
Im looking to put a 2.0 16V Zetec Engine into my mk 4.
The engine im looking at doesnt come with gearbox.
Its been a while since i looked into engine mod/transplants so not sure whats required, but does the zetec match up with/cant be easily adapted to fit the RST gearbox?
The car has been stored off the rd for the past 5 yrs and i now have the time to turn it into a full prepared track car for non-competitive fun use, so im going for something reliable (ie non-turbo).
Thanks in advance
Thanks in advance
I'm sure the rs turbo box bolts straight up but you will need a 1.8 zetec sump / dipstick tube / water pump and flywheel
don't take it as gospel though as i haven't even started doing my mk3 XR3i engine swap yet , hopefully someone with more experience will confirm this for you
JoeyBoyden
04-01-2024 02:36 PM
