erst no fuel why?
hi i have an erst and the injecters arnt getting fuel, the fuel is getting to distrubuter but not getting from the distrubuter to the injecters does any one no what the problem is thanks paul.
I had same prob m8
What i did was bridge the fuel pump relay plug so the pump is going all the time then gently push down on the mfi flag and fuel should start to come out of the injectors.
If you just take a injector out and turn the ignition on so the pump starts up this wont work as there is now a air leak.
Hope this helps
pete
Hope this helps
pete
im not too sure what volt dropping is, but i juts tested the voltage across the connectors when cranking and when not. i think when cranking it went down even more...
could you explain what volt dropping is?
Mc5506
Oct 5, 2015 09:57 PM
