quick help needed with co
Old Jul 26, 2007 | 04:45 PM
2wdsaph ben's Avatar
2wdsaph ben
Default quick help needed with co
got my mot tomorow and i know my saph 1989 cossie runs really rich. if the mot wont pass it what can i do. is it safe to turn down the white co screw by the ecu then turn it back to same position afterwards.
cheers
Old Jul 26, 2007 | 05:41 PM
SafeChav's Avatar
SafeChav
Yes, just don't boost it up at all while you have it altered.
And measure the resistance of the pot so you get it spot on when you set it back
Old Jul 26, 2007 | 06:06 PM
Why not let MOT station adjust it.
Cossies are easily capable of passing emissions test without this lowering nonsense.
Run it around 2.5% CO, and leave it, it will fly through emissions test and be ok.
Old Jul 26, 2007 | 07:31 PM
2wdsaph ben
cheers
i think ill let the mot adjuast it if needed or it might even go through, then ill take it to a local tuner to get it on the rollers and adjusted properly, think its about time i improved my 13mpg,
tabetha are you saying the screw can be adjusted to 2.5 and left like that without needing a further adjustment and will be perfectly safe to use?
Old Jul 26, 2007 | 10:12 PM
mechanic28's Avatar
mechanic28
will be fine at 2.5% most cossie when set up are at 2.5 too 3% at idle
Old Jul 27, 2007 | 08:27 AM
Yes 2.5% CO is perfectly safe and good, and MOT passable too, BONUS.
Anywhere between 2-2.5 is ok.
Old Jul 27, 2007 | 10:42 AM
Ridgey's Avatar
Ridgey
Is the limit for non cat car 5% ?
Old Jul 27, 2007 | 04:48 PM
2wdsaph ben
cheers it passed straight through.mot tester said he didnt see any problem.
matman
Sep 9, 2015 05:45 PM
TomPengelly
13
Aug 22, 2015 06:38 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
col93saphcos
Aug 7, 2015 03:21 PM
