Tuning The Pinto 2.0 Engine
Old Jul 26, 2007 | 04:32 PM
vibrating_cake's Avatar
vibrating_cake
Default Tuning The Pinto 2.0 Engine
i'd rather work with carbs, just because its easier to work on myself and cheaper (not needing mapping sensors etc)
So, im starting with a Standard 2.0 pinto engine, wanting to stay with carbs, what are the first steps you guys would reccomend for tuning this engine.
twim webers, exhaust manifold (will the rs2000 one fit to a capri??)
cam... what else is there to do?
Discuss
Old Jul 26, 2007 | 06:11 PM
CAM,CARB,EXHAUST,HEAD work very well on these not necessarily in that order.
Ask yourself what you want from car power wise, then you will know what spec to do it to, there is a good book by SPEEDPRO, how to power tune ford sohc engines.
I had a few pinto's, 2.1's work well using V6(cologne) pistons, had head by Roland Hayes(HT racing) who are masters of pinto, high torque cam, 32/36 carb in a auto sierra, was way faster than my friends 2L sierra manual injection, and good on the gas as well.
You need to know how much power you want before you know what is best to do.
Old Jul 29, 2007 | 12:37 AM
dox's Avatar
dox
go for twin sidedraughts,big cam,nicely flowed head,get the bottom end
lightend and balanced,knife egde the crank, performance ignition system
if you still got some money left over enlarge the valves etc
also slap in some hi comp pistons my mate had an engine
like that in his mk2 escort and it went really well, gave a few
turbocharged car owners bit of a fright lol.
also dont forget good flowing headers and exhaust, a 5-speed box behind
it makes all the difference to.
Old Jul 31, 2007 | 06:33 PM
siscossie's Avatar
siscossie
3-door moonstone
Default carbs
Me and my mate are just building a 2.2pinto with carbs off an R1 motorbike with a inlet manifold made by bogbrothers near malton, check out there website. They have had some amazing cars with a crazy power increases due to the carbs, check it out
big_Rad
Sep 15, 2017 09:36 AM
Ben26
Aug 27, 2015 08:56 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
