mk 3 escort locks
Old Jul 24, 2007 | 10:43 AM
Barry R's Avatar
Barry R
Default mk 3 escort locks
hello all i have just picked up a mk 3 escort
cabby cheap but it needs a full lock
set so i was wondering will the locks of
any other ford fit? or does it have to be
of a mk 3?
Old Jul 24, 2007 | 12:22 PM
SafeChav's Avatar
SafeChav
The boot lock is unique to the cabriolet, a normal escort one may fit or it may not, ive not tried so can't give you a definite answer.
Also the glovebox lock is only found on cabriolet models.
As per usual ive got a couple of spares sets but not something im willing to let go of at this precise moment in time - how soon are you looking to get a set?
Old Jul 24, 2007 | 07:07 PM
street's Avatar
street
Unique to the mk3 i'm afraid, the mk4 locks don't fit which is a shame as they're loads better!
Old Jul 24, 2007 | 08:54 PM
SafeChav's Avatar
SafeChav
Did i really just read that
Old Jul 24, 2007 | 10:47 PM
street's Avatar
street
Heheh! I always thaught they were a bit more secure, the barrel type key locks fitted to the mk4. My mk3's locks are pretty much worthless! I once baught one of those cheap aftermarket petrol caps to replace mine and the key for that opened my door locks! Quite convenient really, I use it as a spare!
Old Jul 24, 2007 | 11:01 PM
SafeChav's Avatar
SafeChav
The diamond key locks are rubbish man! You can lock any lock with ANY key and most of the time you can use any old worn key to open them aswell.
then theres the fact they are prone to wear, and the petrol cap ALWAYS spins the key inside its plastic so you end up with a key stuck in your petrol cap and an empty tank on the forecourt
Sure the mk4 locks do fit though, the doors are all the same.
Old Jul 25, 2007 | 09:48 AM
street's Avatar
street
Ah, I guess they just look like they are a bit more secure!
The only mk4 Escort lock I don't like are the early ones that use the jagged key that shreds your pockets! Don't see them very often though!
I'm pretty sure mk4 door locks don't fit, I wouldn't bet my life on it but a while ago I remember I tried to put mk4 locks in my mk3 and the shape of the hole was slightly different IIRC, it was a while ago though..... next time i'm down the scrappy i'll have a look and find out for sure
Old Jul 25, 2007 | 12:13 PM
SafeChav's Avatar
SafeChav
Those locks you mention were only on very early Mk4's and were used for probably about a year. The pegs were prone to snap off the key aswell, more than likely changed for obviouos reasons.
If you look on ebay theres some aftermarket locks that a company produced to replace the diamond locks because they weren't very secure
I've not tried fitting an earlier lock myself, but i know if you go to Ford and manage to get a Mk3 door its actually a mk4 door with an adaptor plate so you can fit the mk3 interior door handle, and everything else is a direct fit
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Chopshop85
Sep 12, 2015 06:42 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Bighandsuk
Sep 2, 2015 05:23 PM
