T3 turbo
Old Jul 22, 2007 | 08:48 AM
mk4gartrac's Avatar
mk4gartrac
Default T3 turbo
Just bought a s2 rst the turbos blowing some oil so think is due a rebuild is it worth buying a kit and doing myself or should i get it recond by a pro?if so where?
Old Jul 22, 2007 | 12:34 PM
There is a trader on here that does them G B turbo's I think he is called, if not I use the TURBOCENTRE 01924 404112, ANDY or CRAIG.
I would not DIY personally.
Old Jul 22, 2007 | 03:39 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
Thanks for the mention tabby
Standard recon with all genuine garrett parts is £225
Pop it in the post and you ll have it 3 days later like new
Go to contact page at www.gbturbosolutions.org.uk for details of where to send to
Thanks and regards,
Carl
G.B Turbo Solutions
Old Jul 23, 2007 | 06:31 AM
mk4gartrac's Avatar
mk4gartrac
So has anyone re built there own turbo?
Old Jul 23, 2007 | 06:57 AM
I THOUGHT about it, but then thought what if it then needs balancing or explodes it bits into the intake, I was shaking like a little girl with that thought so left it alone, will leave it to GB next time.
Old Jul 23, 2007 | 05:28 PM
SafeChav's Avatar
SafeChav
I have rebuilt my own T3.
A kit won't necessarily solve your problem, it depends on what exactly is wrong with yours.
There could be parts that are worn and are beyond salvage, or then again you might be lucky...........
Old Jul 25, 2007 | 03:53 PM
mk4gartrac's Avatar
mk4gartrac
Ive just removed the turbo pipes to check the turbo and found oil in the pipes before and after the turbo the engine dose not smoke but over boost massivley and cuts out like hitting brick wall at full chatter.I had a bit of oil coming out of the dumpvalve after giving it a thrashing the other day so thought was the turbo but now seeing oil before turbo im now thinking exsesive oil passing through the breather system.Any thoughts on this? It also dose not tick over when warm but drives realy nicely (except too much boost )
Old Jul 25, 2007 | 05:15 PM
jon@work's Avatar
jon@work
re too much boost - check your AMAL valve clicks when the ignition is turned on - if not, check wiring to it or replace valve
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
